4 Replies Latest reply on Jun 16, 2009 2:09 AM by tf-dtp
    Density of spot colors should be exported correctly to PDF in CMYK mode
    tf-dtp
      I want to use a spot color like Pantone that will be exported to a different plate from CMYK in the PDF file. Generally that works, when I export the FrameMaker document tuo PDF and select to export it as PDF.
      BUT:
      If I assign e.g. 50% density of the defined spot color to an object, it appears also with an opacity of 100% in the PDF. This happens also, if i define an extra color with 50% of the spot color.
      (see attachments)
      In RGB the colors are exported correctly, but that cannot be used for the further print process (CMYK + 1 spot color / or black + spot color)
