6 Replies Latest reply on Sep 30, 2008 2:18 PM by bregent
    Code contains 9 errors. Help please!
    EstherH
      I used http://validator.w3.org to check my code. It showed 9 errors. I have no idea about HTML and code, and could not understand what was wrong and how to fix them. I attached code and error message below.
      Could anyone advise me? Many thanks.
      Esther
      Line 168 contains 7 errors:
      <embed src="../Flash frontpage/Foundations and Fverview Slides.swf" quality="high" pluginspage=" http://www.adobe.com/shockwave/download/download.cgi?P1_Prod_Version=ShockwaveFlash" type="application/x-shockwave-flash" width="329" height="451"></embed>
      1 Column 16: there is no attribute "src".
      <embed src="../Flash frontpage/Foundations and Overview Slides.swf" quality
      2 Column 81: there is no attribute "quality".
      …ons and Overview Slides.swf" quality="high" pluginspage=" http://www.adobe.com
      3 Column 100: there is no attribute "pluginspage".
      …ides.swf" quality="high" pluginspage=" http://www.adobe.com/shockwave/download
      4 Column 191: there is no attribute "type".
      …P1_Prod_Version=ShockwaveFlash" type="application/x-shockwave-flash" width="3
      5 Column 229: there is no attribute "width".
      …application/x-shockwave-flash" width="329" height="451"></embed>
      6 Column 242: there is no attribute "height".
      …-shockwave-flash" width="329" height="451"></embed>
      7 Column 247: element "embed" undefined.
      …kwave-flash" width="329" height="451"></embed>
      Line 164 contains 2 errors:
      AC_FL_RunContent( 'codebase',' http://download.macromedia.com/pub/shockwave/cabs/flash/swflash.cab#version=9,0,28,0','wid th','329','height','451','title','Foundation &amp; Overview','src','../Flash frontpage/Foundations and Overview Slides','quality','high','pluginspage',' http://www.adobe.com/shockwave/download/download.cgi?P1_Prod_Version=ShockwaveFlash','movi e','../Flash frontpage/Foundations and Overview Slides' ); //end AC code
      1. Line 164, Column 165: character "&" is the first character of a delimiter but occurred as data.
      …','height','451','title','Foundation & Overview','src','../Flash frontpage/Fo
      2. Line 164, Column > 80: XML Parsing Error: xmlParseEntityRef: no name.
      …ad.macromedia.com/pub/shockwave/cabs/flash/swflash.cab#version=9,0,28,0','wid…
      Line 341 and 342 are:
      <map name="Map" id="Map">
      </map></body>
      Line 342 has 1 error
      Line 342, Column 5: end tag for "map" which is not finished.
      </map></body>
        • 1. Re: Code contains 9 errors. Help please!
          Level 7
          I already answered this in your previous thread. Did you see it?
          Murray --- ICQ 71997575
          Adobe Community Expert
          (If you *MUST* email me, don't LAUGH when you do so!)
          http://www.projectseven.com/go - DW FAQs, Tutorials & Resources
          http://www.dwfaq.com - DW FAQs, Tutorials & Resources
          "EstherH" <webforumsuser@macromedia.com> wrote in message
          news:gaui8i$82e$1@forums.macromedia.com...
          > Hi,
          > have no
          > to
          > Esther
          > quality="high"
          > quality
          > ?ons and Overview Slides.swf" quality="high"
          > ?ides.swf" quality="high"
          > width="3
          > ?application/x-shockwave-flash" width="329" height="451"></embed>
          > ?-shockwave-flash" width="329" height="451"></embed>
          > ?kwave-flash" width="329" height="451"></embed>
          > AC_FL_RunContent(
          > version=9,0,28,0','width','329','height','451','title','Foundation &amp;
          > download.cgi?P1_Prod_Version=ShockwaveFlash','movie','../Flash
          > delimiter
          > ?','height','451','title','Foundation & Overview','src','../Flash
          > frontpage/Fo
          > ?ad.macromedia.com/pub/shockwave/cabs/flash/swflash.cab#version=9,0,28,0','wid?
          > </map></body>
          > </map></body>
          • 2. Re: Code contains 9 errors. Help please!
            EstherH Level 1
            Hi Murray,
            I just checked the other thread "Page looks different in IE and Firefox", but did not find your post. Do you mind helping me to find it? Sorry for the inconvenience......
            Many thanks...
            Esther
            • 3. Re: Code contains 9 errors. Help please!
              Level 7
              Posted 9/18 @ 6:58am -
              You can ignore all but the last. Typically embedded Flash elements when
              done the way you have will not validate. That will not affect the rendering
              of the page.
              It appears that you have an empty image map on the page -
              > </map></body>
              Just change those two lines to this -
              </body>
              (i.e., remove the empty map altogether)
              After fixing those are you still getting rendering differences? Are you
              using tables for your layout? Do you count many colspan and rowspan
              attributes in your code (hint: do a current document find for each of those
              two attributes in the source)?
              news:gav1q8$p81$1@forums.macromedia.com...
              > Hi Murray,
              > but
              > inconvenience......
              > Many thanks...
              > Esther
              • 4. Re: Code contains 9 errors. Help please!
                Level 7
                .oO(EstherH)
                > Esther
                The 'embed' element is invalid HTML, but supported in almost every
                browser. If you want to do it standards-compliant, just use an 'object'
                element, which works well enough in all modern browsers and IE >= 6.
                Flash Satay: Embedding Flash While Supporting Standards
                http://www.alistapart.com/articles/flashsatay
                Micha
                • 5. Re: Code contains 9 errors. Help please!
                  EstherH Level 1
                  I will just ignore all the errors reported as long as the pages looks good in Firefox or IE.
                  • 6. Re: Code contains 9 errors. Help please!
                    bregent Most Valuable Participant
                    That's a bad strategy. It's OK to ignore some errors as long as you understand them. They may be warning you of problems that will occur in other browsers, or sometime in the future.
