0 Replies Latest reply on Jun 10, 2009 8:59 AM by Peter Farland
    [svn:fx-trunk] 7716: Partial fix for SDK-21182.
    Peter Farland Level 3
      Revision: 7716
      Author:   pfarland@adobe.com
      Date:     2009-06-10 08:59:13 -0700 (Wed, 10 Jun 2009)
      Log Message:
      Partial fix for SDK-21182. We now set the default compatibility version to the current version and thus the compatibility version string will no longer be null by default (but would be the current version if no override was set). This also means the compiler now matches the ActionScript FlexVersion class.
      This change does not address the issue of revision/minor/major-version fallback in order to select the next most appropriate defaults-x.y.z.css file for any given version.
      Also updated flex-jars eclipse project classpath to reflect recent Batik jar consolidation.
      QE: Yes, if we didn't previously, please change any negative test cases that were checking for --compatibility-version=4 as this is still valid (and is the default).
      Doc: No
      Checkintests: Pass
      Reviewer: Paul
      Bugs:
      SDK-21182 - Fix logic surrounding compatibility version and SWC default.css selection during PreLink
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-21182
      Modified Paths:
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/common/MxmlConfiguration.java
