0 Replies Latest reply on Sep 15, 2008 11:29 PM by COKFlex
    Changing column width dynamically causing vertical lines appearing in Advanced Data Grid
    COKFlex Level 1
      Dear All,
      I am using Advanced Data Grid to dislay series of rows, has 4 columns. My screen resolution is 1024x768.
      I equally distributed the width of the columns to 500. If I tend to change the width dynamically I am getting vertical lines (not the actual vertical lines, since I have set that verticalLines = false).
      Also I am not able to set the width which can fit to the screen size. Some times If I set width as 300 for all the columns made the lines disappear which makes the width value unpredictable.
      below code shows two set of values I passed to the column width. first one is read from the config file using a function and the second one hardcoded to 500.
      I am happy to give the screenshot, but I dont know how to attach here.
      Any help would be appreciated.
      CokFlex
