• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Automatically eliminating a record at the begining of a new month
Participant ,
Jun 10, 2009 Jun 10, 2009
Hello;
I have a little app I am building that makes a list of records organized by the month the record falls in. this is how it looks:
JUNE
Record title goes here as a link
record date
the location of the event
<!--- all the records for JUNE fall in here, the link goes to a page with all the details --->
JULY
same thing as June
and so on....Now as it is the code works fine, BUT when lets say it goes to JULY, the JUNE records are still visible, I want them to go away after the month passes. Is that possibly an easy task using the code I wrote for this? The don't have to be deleted from the DB, but they need to "disappear" in the web site when the month passes.
This is the code:
<cfquery name="gTempx1" datasource="#APPLICATION.dataSource#" blockfactor="5">
SELECT DISTINCT(YEAR(eventDate)) AS gTempx2, display
FROM events
WHERE display = 0 AND YEAR(eventDate) >= #dateFormat(now(), 'yyyy')# ORDER BY YEAR(eventDate) ASC
</cfquery>
<cfset distintYearEventDate = DateFormat(now(), "yyyy")>
<cfset tempdx = DateFormat(now(), "mm/dd/yy")>
                <cfif DateFormat(now(), "mm/dd/yy") GTE "#tempdx#">
                  <cfoutput query="gTempx1">
                    <cfset gTempx5 = "#gTempx1.gTempx2#">
                      <cfset gTempx6 = DateFormat(now(), "yyyy")>
                      <cfset gTempx7 = DateFormat(now(), "mmmm")>
                      <cfset distintYear = DateFormat(now(), "yyyy")>
                    </cfif>
                    <cfquery name="gTempx3" datasource="#APPLICATION.dataSource#" blockfactor="5">
                      SELECT DISTINCT(MONTH(eventDate)) AS gTempx4, display
       FROM events
       WHERE display = 0 AND YEAR(eventDate) = #gTempx5#
                      ORDER BY MONTH(eventDate) ASC
                    </cfquery>
                    <cfset dateAdd = DateFormat(now(), "mmmm")>
                    <cfset thirtyTempx1 = "#dateFormat(dateAdd('d',-30,Now()),'mm/dd/yyyy')#">
                    <cfloop query="gTempx3">
                      <cfset gTempx6 = "#gTempx4#/01/#gTempx5#">
<b><u>#ucase("#DateFormat(gTempx6,'mmmm YYYY')#")#</u></b>
<cfquery name="GetRecordevent" datasource="#APPLICATION.dataSource#">
      SELECT events.title AS ViewField2, events.eventDate AS ViewField3, events.location AS ViewField5, events.ID AS ID
      FROM events
      WHERE display = 0 AND YEAR(eventDate) = #gTempx5# AND MONTH(eventDate) = #gTempx3.gTempx4#
      ORDER BY DAY(eventDate) ASC
                      </cfquery>
                      <cfloop query="GetRecordevent">
<a href="detail.cfm?ID=#ID#" class="subNav">
#ViewField2#
#dateformat(ViewField3, "mmm-dd-yyyy")#<br>
</cfloop>
</cfloop>
</cfoutput>
</cfif>
can anyone help me out? Don't know what to tweekout on this to make it rotate through the months like a normal calendar.
thank you
CFmonger
TOPICS
Advanced techniques
Views
995
Translate
Translate
Report
Report
Community guidelines
community guidelines
Contributor , Jun 11, 2009 Jun 11, 2009
WHERE eventDate > #NOW()#
Votes
Translate
Translate
Contributor ,
Select only those records from July forward in your SQL statement.
Votes
Translate
Translate
Report
Report
Participant ,
How would I write that into my where statement as it is? I did some changes in the code and got ride of some old functions that are not being used any longer.Would I add mm, Now() to the where statement?
These are th query's now. there are 3 of them, and this change will have to effect all 3, I believe.
Query 1:
         FROM events
         WHERE YEAR(eventDate) >= #dateFormat(now(), 'yyyy')#
</cfquery>
Query 2
       FROM events
       WHERE YEAR(eventDate) = #gTempx5#
</cfquery>
Query 3
      FROM events
      WHERE YEAR(eventDate) = #gTempx5# AND MONTH(eventDate) = #gTempx3.gTempx4#
</cfquery>
So would I add something like this to my where:
WHERE YEAR(eventDate) >= #dateFormat(now(), 'yyyy','mm')#
I know that isn't right, I am not distinguishing the month now()
Votes
Translate
Translate
Report
Report
Contributor ,
I only glanced over your code, but I don't understand why the YEAR() function exists in your queries given what you've described you're trying to do. Getting rid of that it seems would give a desirable outcome.
Votes
Translate
Translate
Report
Report
Participant ,
So I should change it to this:
                   SELECT DISTINCT(MONTH(eventDate)) AS gTempx2
                   FROM events
                   WHERE MONTH(eventDate) >= #dateFormat(now(), 'mm')#
then change my cfset to
<cfset distintMonthEventDate = DateFormat(now(), "mm")>
or is there more then this?
thanks
CF
Votes
Translate
Translate
Report
Report
Contributor ,
Votes
Translate
Translate
Report
Report
Participant ,
ok, I am adding that in, but now it isn't showing anything on the page, not an error either.
this is what I did:
q1
                   FROM events
                </cfquery>
q2
       FROM events
       WHERE eventDate > #NOW()# = #gTempx5#
                    </cfquery>
q3
      events.ID AS ID
      FROM events
                      </cfquery>
not sure what to do in q3, all 3 depend on each other.
do I use the query I showed with the distinct month and change all the years to month and add your query?
kind of tried that and so far not working
Votes
Translate
Translate
Report
Report
Participant ,
LATEST
I am getting someplace now.
I have been messing with the where statement. I have it so it will eliminate the previous months records, but it is duplicating the records now and makeing them for lets say I have a record is set for July 2009 that same record will appear as July 2010 as well.
This is what I changed my 2 querys to:
q1
                FROM events
               </cfquery>
q2.
       FROM events
                    </cfquery>
q3.
                        SELECT events.title AS ViewField2, events.eventDate AS ViewField3, events.eventTime
                        AS ViewField4, events.location AS ViewField5, events.ID AS ID
      FROM events
      WHERE eventDate > #NOW()# = #gTempx5# AND MONTH(eventDate) = #gTempx3.gTempx4#
                      </cfquery>
can anyone help me fix this so it works properly. for some reason it is making the same records appear every year.
Votes
Translate
Translate
Report
Report
Resources
Documentation
