0 Replies Latest reply on Jun 10, 2009 5:25 PM by rfrishbe
    [svn:fx-trunk] 7732: VideoPlayer changes: mostly PARB but fixing a few bugs as well.
    rfrishbe Level 3
      Revision: 7732
      Author:   rfrishbe@adobe.com
      Date:     2009-06-10 16:24:50 -0700 (Wed, 10 Jun 2009)
      Log Message:
      Bugs:
      Fix VideoPlayer bug with live streaming so the pause button comes up when we first start playing (rather than a play button).  This was caused by an underlying FLVPlayback VideoPlayer bug, and I modified the underlying VideoPlayer code to fix it.
      MuteButton wasn't showing the correct volume when it first pops up in fullScreen mode.  This is because the MuteButtonSkin needed to grab the volume property when it loaded up initially.  It was doing this in the normal case, but not the fullScreen and wireframe case.
      FullScreen DropShadow: Change volume bar dropshadow to be a real dropshadow instead of using RectangularDropShadow.  This is the same change as yesterday...just in the fullScreen case.
      API Changes:
      ScrubBar.bufferedRange:Array -> bufferedStart, bufferedEnd
      VolumeBar: Add isDropDownOpen() which facades to isOpen on the DropDownController.
      MuteButton:  Change ?\226?\128?\156value?\226?\128?\157 property to ?\226?\128?\156volume?\226?\128?\157.  Add ?\226?\128?\156muted?\226?\128?\157 property and a mutedChange event.
      Get rid of VideoPlayerVolumeBarEvent: put the constant on FlexEvent instead: FlexEvent.MUTED_CHANGE
      VideoPlayer.muteButton: Changed type from ToggleButton to MuteButton.
      Make DropDownList/VolumeBar.dropDownController_openHandler() and closeHandler() mx_internal instead of protected.
      Class Renames:
      spark.components.supportClasses.StreamingVideoSource -> spark.components.mediaClasses.StreamingVideoSource
      spark.components.supportClasses.StreamItem -> spark.components.mediaClasses.StreamItem
      spark.components.VideoPlayerScrubBar -> spark.components.mediaClasses.ScrubBar
      spark.components.VideoPlayerVolumeBar -> spark.components.mediaClasses.VolumeBar
      spark.components.VideoPlayerVolumeBarMuteButton -> spark.components.mediaClasses.MuteButton
      spark.skins.default.VideoPlayerFullScreenButtonSkin -> spark.skins.default.mediaClasses.normal.FullScreenButtonSkin
      spark.skins.default.VideoPlayerPlayPauseButtonSkin -> spark.skins.default.mediaClasses.normal.PlayPauseButtonSkin
      spark.skins.default.VideoPlayerScrubBarSkin -> spark.skins.default.mediaClasses.normal.ScrubBarSkin
      spark.skins.default.VideoPlayerScrubBarThumbSkin -> spark.skins.default.mediaClasses.normal.ScrubBarThumbSkin
      spark.skins.default.VideoPlayerScrubBarTrackSkin -> spark.skins.default.mediaClasses.normal.ScrubBarTrackSkin
      spark.skins.default.VideoPlayerVolumeBarMuteButtonSkin -> spark.skins.default.mediaClasses.normal.MuteButtonSkin
      spark.skins.default.VideoPlayerVolumeBarSkin -> spark.skins.default.mediaClasses.normal.VolumeBarSkin
      spark.skins.default.VideoPlayerVolumeBarThumbSkin -> spark.skins.default.mediaClasses.normal.VolumeBarThumbSkin
      spark.skins.default.VideoPlayerVolumeBarTrackSkin -> spark.skins.default.mediaClasses.normal.VolumeBarTrackSkin
      spark.skins.default.VideoPlayerFullScreenFullScreenButtonSkin -> spark.skins.default.mediaClasses.fullScreen.FullScreenButtonSkin
      spark.skins.default.VideoPlayerFullScreenPlayPauseButtonSkin -> spark.skins.default.mediaClasses.fullScreen.PlayPauseButtonSkin
      spark.skins.default.VideoPlayerFullScreenScrubBarSkin -> spark.skins.default.mediaClasses.fullScreen.ScrubBarSkin
      spark.skins.default.VideoPlayerFullScreenScrubBarThumbSkin -> spark.skins.default.mediaClasses.fullScreen.ScrubBarThumbSkin
      spark.skins.default.VideoPlayerFullScreenScrubBarTrackSkin -> spark.skins.default.mediaClasses.fullScreen.ScrubBarTrackSkin
      spark.skins.default.VideoPlayerFullScreenVolumeBarMuteButtonSkin -> spark.skins.default.mediaClasses.fullScreen.MuteButtonSkin
      spark.skins.default.VideoPlayerFullScreenVolumeBarSkin -> spark.skins.default.mediaClasses.fullScreen.VolumeBarSkin
      spark.skins.default.VideoPlayerFullScreenVolumeBarThumbSkin -> spark.skins.default.mediaClasses.fullScreen.VolumeBarThumbSkin
      spark.skins.default.VideoPlayerFullScreenVolumeBarTrackSkin -> spark.skins.default.mediaClasses.fullScreen.VolumeBarTrackSkin
      spark.skins.wireframe.VideoPlayerFullScreenFullScreenButtonSkin -> spark.skins.wireframe.mediaClasses.fullScreen.FullScreenButtonSkin
      spark.skins.wireframe.VideoPlayerFullScreenButtonSkin -> spark.skins.wireframe.mediaClasses.FullScreenButtonSkin
      spark.skins.wireframe.VideoPlayerPlayPauseButtonSkin -> spark.skins.wireframe.mediaClasses.PlayPauseButtonSkin
      spark.skins.wireframe.VideoPlayerScrubBarSkin -> spark.skins.wireframe.mediaClasses.ScrubBarSkin
      spark.skins.wireframe.VideoPlayerScrubBarThumbSkin -> spark.skins.wireframe.mediaClasses.ScrubBarThumbSkin
      spark.skins.wireframe.VideoPlayerScrubBarTrackSkin -> spark.skins.wireframe.mediaClasses.ScrubBarTrackSkin
      spark.skins.wireframe.VideoPlayerVolumeBarMuteButtonSkin -> spark.skins.wireframe.mediaClasses.MuteButtonSkin
      spark.skins.wireframe.VideoPlayerVolumeBarSkin -> spark.skins.wireframe.mediaClasses.VolumeBarSkin
      spark.skins.wireframe.VideoPlayerVolumeBarThumbSkin -> spark.skins.wireframe.mediaClasses.VolumeBarThumbSkin
      spark.skins.wireframe.VideoPlayerVolumeBarTrackSkin -> spark.skins.wireframe.mediaClasses.VolumeBarTrackSkin
      QE Notes: -
      Doc Notes: -
      Bugs: SDK-21727, SDK-21722, SDK-21675
      Reviewer: Deepa
      tests: checkintest (seem to fail due to local changes to ScrollBar, which I'm not checking in here)
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-21727
          http://bugs.adobe.com/jira/browse/SDK-21722
          http://bugs.adobe.com/jira/browse/SDK-21675
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/flex4/defaults.css
          flex/sdk/trunk/frameworks/projects/flex4/src/Flex4Classes.as
          flex/sdk/trunk/frameworks/projects/flex4/src/fl/video/VideoPlayer.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/DropDownList.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/VideoPlayer.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/primitives/VideoElement.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/default/VideoPlayerSkin.mxml
          flex/sdk/trunk/frameworks/projects/framework/src/mx/events/FlexEvent.as
          flex/sdk/trunk/frameworks/projects/wireframe/defaults.css
          flex/sdk/trunk/frameworks/projects/wireframe/src/WireframeClasses.as
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/VideoPlayerSkin.mx ml
          flex/sdk/trunk/frameworks/spark-manifest.xml
      Added Paths:
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/mediaClasses/
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/mediaClasses/MuteButton.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/mediaClasses/ScrubBar.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/mediaClasses/StreamItem.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/mediaClasses/StreamingVideo Source.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/mediaClasses/VolumeBar.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/default/mediaClasses/
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/default/mediaClasses/fullScreen/
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/default/mediaClasses/fullScreen/ FullScreenButtonSkin.mxml
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/default/mediaClasses/fullScreen/ MuteButtonSkin.mxml
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/default/mediaClasses/fullScreen/ PlayPauseButtonSkin.mxml
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/default/mediaClasses/fullScreen/ ScrubBarSkin.mxml
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/default/mediaClasses/fullScreen/ ScrubBarThumbSkin.mxml
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/default/mediaClasses/fullScreen/ ScrubBarTrackSkin.mxml
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/default/mediaClasses/fullScreen/ VolumeBarSkin.mxml
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/default/mediaClasses/fullScreen/ VolumeBarThumbSkin.mxml
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/default/mediaClasses/fullScreen/ VolumeBarTrackSkin.mxml
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/default/mediaClasses/normal/
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/default/mediaClasses/normal/Full ScreenButtonSkin.mxml
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/default/mediaClasses/normal/Mute ButtonSkin.mxml
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/default/mediaClasses/normal/Play PauseButtonSkin.mxml
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/default/mediaClasses/normal/Scru bBarSkin.mxml
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/default/mediaClasses/normal/Scru bBarThumbSkin.mxml
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/default/mediaClasses/normal/Scru bBarTrackSkin.mxml
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/default/mediaClasses/normal/Volu meBarSkin.mxml
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/default/mediaClasses/normal/Volu meBarThumbSkin.mxml
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/default/mediaClasses/normal/Volu meBarTrackSkin.mxml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/mediaClasses/
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/mediaClasses/FullS creenButtonSkin.mxml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/mediaClasses/MuteB uttonSkin.mxml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/mediaClasses/PlayP auseButtonSkin.mxml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/mediaClasses/Scrub BarSkin.mxml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/mediaClasses/Scrub BarThumbSkin.mxml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/mediaClasses/Scrub BarTrackSkin.mxml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/mediaClasses/Volum eBarSkin.mxml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/mediaClasses/Volum eBarThumbSkin.mxml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/mediaClasses/Volum eBarTrackSkin.mxml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/mediaClasses/fullS creen/
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/mediaClasses/fullS creen/FullScreenButtonSkin.mxml
      Removed Paths:
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/VideoPlayerScrubBar.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/VideoPlayerVolumeBar.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/VideoPlayerVolumeBarMuteBut ton.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/supportClasses/StreamItem.a s
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/supportClasses/StreamingVid eoSource.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/events/VideoPlayerVolumeBarEvent.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/default/VideoPlayerFullScreenBut tonSkin.mxml
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/default/VideoPlayerFullScreenFul lScreenButtonSkin.mxml
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/default/VideoPlayerFullScreenPla yPauseButtonSkin.mxml
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/default/VideoPlayerFullScreenScr ubBarSkin.mxml
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/default/VideoPlayerFullScreenScr ubBarThumbSkin.mxml
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/default/VideoPlayerFullScreenScr ubBarTrackSkin.mxml
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/default/VideoPlayerFullScreenVol umeBarMuteButtonSkin.mxml
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/default/VideoPlayerFullScreenVol umeBarSkin.mxml
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/default/VideoPlayerFullScreenVol umeBarThumbSkin.mxml
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/default/VideoPlayerFullScreenVol umeBarTrackSkin.mxml
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/default/VideoPlayerPlayPauseButt onSkin.mxml
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/default/VideoPlayerScrubBarSkin. mxml
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/default/VideoPlayerScrubBarThumb Skin.mxml
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/default/VideoPlayerScrubBarTrack Skin.mxml
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/default/VideoPlayerVolumeBarMute ButtonSkin.mxml
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/default/VideoPlayerVolumeBarSkin .mxml
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/default/VideoPlayerVolumeBarThum bSkin.mxml
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/default/VideoPlayerVolumeBarTrac kSkin.mxml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/VideoPlayerFullScr eenButtonSkin.mxml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/VideoPlayerFullScr eenFullScreenButtonSkin.mxml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/VideoPlayerPlayPau seButtonSkin.mxml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/VideoPlayerScrubBa rSkin.mxml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/VideoPlayerScrubBa rThumbSkin.mxml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/VideoPlayerScrubBa rTrackSkin.mxml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/VideoPlayerVolumeB arMuteButtonSkin.mxml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/VideoPlayerVolumeB arSkin.mxml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/VideoPlayerVolumeB arThumbSkin.mxml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/VideoPlayerVolumeB arTrackSkin.mxml
