1. Re: Session engine and Export as Binary
Steven.. Jun 10, 2009 7:04 PM (in response to John.Kordas)The way to call it is with dummy jsx file like this
#target indesign #targetengine "session" var myFile = new File (app.activeScript.parent.parent.fsName + '/myFileName.jsxbin'); if (myFile.exists) app.doScript(myFile) ,ScriptLanguage.JAVASCRIPT else alert(myFile.fsName + " doesn't exist");
Good luck
Steven
2. Re: Session engine and Export as Binary
John.Kordas Jul 6, 2009 8:12 PM (in response to Steven..)Thanks Steven,
I've been tied up with acouple of other scripts so did not get a chance to got through this until now and I'm still getting the same result as if I export the above script as a binary file.
I call the script above SessionTest.jsxbin applied this to the example you posted and placed the SessionTestCall.jsx with the SessionTest.jsxbin file in the same folder and tried to run the SessionTestCall.jsx file. The window pops up in Indesign but closes straight away, as as if you execute the SessionTest.jsxbin file.
Have I got this correct?
#target indesign
var myFile = new File (app.activeScript.parent.fsName + '/SessionTest.jsxbin');
if (myFile.exists)
app.doScript(myFile ) ,ScriptLanguage.JAVASCRIPT
else
alert(myFile.fsName + " doesn't exist"); -
3. Re: Session engine and Export as Binary
Steven.. Jul 6, 2009 8:45 PM (in response to John.Kordas)app.doScript(myFile ) ,ScriptLanguage.JAVASCRIPT
should be
app.doScript(myFile ,ScriptLanguage.JAVASCRIPT)
I don't know if that will help
4. Re: Session engine and Export as Binary
John.Kordas Jul 6, 2009 9:56 PM (in response to Steven..)Unfortunately Steven the change still causes the window to pop open then close straight away.
Cheers, John.
5. Re: Session engine and Export as Binary
liedzeit Jul 7, 2009 1:10 AM (in response to John.Kordas)Maybe you have to reset userinteractionlevel? I have had this recently. Window popping up and disappearing again.
Ralf
6. Re: Session engine and Export as Binary
Thomas B. Nielsen Jul 7, 2009 2:24 AM (in response to John.Kordas)Hi John,
Do not export the dummy file as binary.
targetengine session can not be loaded from a jsxbin file, so instead you use a dummy file in jsx, and let that load the jsxbin (the code you do not want others to see, or edit).
7. Re: Session engine and Export as Binary
John.Kordas Jul 7, 2009 6:57 PM (in response to Thomas B. Nielsen)Thanks liedzeit and Thomas,
I've checked myuserInteractionLevel
$.write(app.scriptPreferences.userInteractionLevel) = 1699311169 ( INTERACT_WITH_ALL )
interestingly while looking for some info on the userInteractionLevel I stumbled on a reply post form Robert_Tkaczyk (adobescripts.com) and I saw a script PhotoManager_CS3 I thought I'd give a try. After running acouple of tests I ran the above script again and this time I got:
$.write(app.scriptPreferences.userInteractionLevel) = 1699640946 ( NEVER_INTERACT )
Not that I want to move away form my issue but would this cause issues if other scripts change settings that you expect to be something else?
In any case I'm still getting the window popping up and closing straight away. I also tried what Thomas suggested and removed:
#target indesign
#targetengine "session"from the top of the SessionTest.jsxbin file but still get the same result. Any other suggestions are welcome.
8. Re: Session engine and Export as Binary
John.Kordas Jul 7, 2009 7:14 PM (in response to John.Kordas)This has probably been done by someone else but I know I've had to check theuserInteractionLevel before and to save me time I put this together so i can quickly check what the current setting is.
var myUsrInter = app.scriptPreferences.userInteractionLevel;
switch (myUsrInter)
case 1699640946:
alert("Your userInteractionLevel is set to NEVER_INTERACT");
break;
case 1699311169:
alert("Your userInteractionLevel is set to INTERACT_WITH_ALL");
break;
case 1699311170:
alert("Your userInteractionLevel is set to INTERACT_WITH_ALERTS");
break;
9. Re: Session engine and Export as Binary
Thomas B. Nielsen Jul 8, 2009 12:43 AM (in response to John.Kordas)Hi John,
Create a folder in your Indesign Scripts Folder Panel, lets call it myFolder.
In that folder we will put two files, the first is your script, as a binary, the second is a loader file as jsx.
The folowing should be pasted into ESTK and exported as jsxbin, save the file in myFolder as myScript.jsxbin:
app.scriptPreferences.userInteractionLevel = UserInteractionLevels.interactWithAll;
if(app.documents.length != 0){
var myDialog = new Window('palette','Starting Pg No');
myDialog.dPgNo = myDialog.add('panel',undefined,'File details');
myDialog.dPgNo.alignChildren = 'left';
myDialog.dPgNo.myPgNo = myDialog.dPgNo.add('group');
myDialog.dPgNo.myPgNo.myGroup = myDialog.dPgNo.myPgNo.add('group');
myDialog.dPgNo.btnGroup = myDialog.dPgNo.add('group');
with (myDialog.dPgNo){
myPgNo.myGroup.orientation = 'column';
myPgNo.myGroup.alignChildren = 'right';
myPgNo.myGroup.preferredSize = [90,15];
myPgNo.myGroup.st = myPgNo.myGroup.add('statictext',undefined,'Your Doc starting page is:');
myPgNo.et = myPgNo.add('edittext', undefined, app.activeDocument.pages[0].name)
btnGroup.btn = btnGroup.add('button', undefined, 'Update');
btnGroup.alignment = 'right';
myDialog.show();myDialog.dPgNo.btnGroup.btn.onClick = function() {
var myPagestart = myDialog.dPgNo.myPgNo.et.text;
myDialog.close();
if (app.activeDocument.pages[0].name != myPagestart){
app.activeDocument.pages[0].appliedSection.continueNumbering = false;
app.activeDocument.pages[0].appliedSection.pageNumberStart = parseInt(myPagestart);
app.activeDocument.pages[0].appliedSection.sectionPrefix = "";
alert("Your document start page has been changed to "+myPagestart+".");
myDialog.show();
}else{
alert("Please open a document and try again.");
}The folowing should be pasted into ESTK and saved as jsx, save the file in myFolder as myLoader.jsx:
#target indesign
var myScript = loadScript("myScript.jsxbin");
if(myScript != undefined) {
// execute it
eval(myScript);
}function getScriptsFolderPath() {
try {
var script = app.activeScript;
} catch(e) {
// we are running from the ESTK
var script = File(e.fileName);
return script.path + "/";
}function loadScript (filename) {
var file = File(getScriptsFolderPath() + filename);var script = undefined;
if (file.exists) {
file.open();
script = file.read();
file.close();
} else {
alert("Failed to locate the file: " + filename);
exit();
// we return the script rather than calling eval() right here
// because the results of eval() are only valid within the
// scope of the function that calls eval()
return script;
}Now just open Indesign and run the script myLoader.jsx and it should work.
10. Re: Session engine and Export as Binary
John.Kordas Jul 8, 2009 6:09 PM (in response to Thomas B. Nielsen)Thanks Thomas
works no probs.
Much appreciated, John.
