0 Replies Latest reply on Jun 10, 2009 6:31 PM by rfrishbe
    [svn:fx-trunk] 7734: Adding back in dataTip to ScrubBarSkin--found a workaround to a bug I just filed : SDK-21737
    rfrishbe Level 3
      Revision: 7734
      Author:   rfrishbe@adobe.com
      Date:     2009-06-10 18:11:25 -0700 (Wed, 10 Jun 2009)
      Log Message:
      Adding back in dataTip to ScrubBarSkin--found a workaround to a bug I just filed: SDK-21737
      Removing dead code in UIMovieClip.
      Also changing VideoPlayer so that when going in fullscreen mode it positions itself at (0,0) rather than (-2width, -2height).  This was causing issues with popups. However, the code in PopUpAnchor to deal with fullScreenSourceRect is still needed when the fullScreenSourceRect isn't positioned at (0,0), and I'm not sure how tolerant any of our other popup logic is to fullscreens, but positioning it at (0,0) seems safer, and we should always be the top component now that we are placing ourselves on the application.
      QE Notes: -
      Doc Notes: -
      Bugs: SDK-21737
      Reviewer: Chiedo
      tests: checkintest (seem to fail due to local changes to ScrollBar, which I'm not checking in here)
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-21737
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/flash-integration/src/mx/flash/UIMovieClip.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/VideoPlayer.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/default/mediaClasses/fullScreen/ ScrubBarSkin.mxml
