[svn:fx-trunk] 7736:
pmd12345 Jun 10, 2009 10:53 PMRevision: 7736
Author: peted@adobe.com
Date: 2009-06-10 22:53:07 -0700 (Wed, 10 Jun 2009)
Log Message:
Changes to the Asc parser & scanner.
These are mostly about simplifying the parser/scanner interface, fixes to parser syntax error handling and use of an array for binary precedence lookup.
Also, a lot of changes to asc-tests, since error format changed slightly.
I don?\226?\128?\153t expect much in overall performance improvements, since the parser uses less than 2% of compile time.
Note that tests based on matching prior syntax error messages may fail.
QE Notes: All possible test cases should be run
Doc Notes: None
Reviewer: Gaurav
tests: checkintests tamarin, asc-tests, performance tests
Modified Paths:
flex/sdk/trunk/modules/asc/src/java/macromedia/asc/parser/Parser.java
flex/sdk/trunk/modules/asc/src/java/macromedia/asc/parser/Scanner.java
flex/sdk/trunk/modules/asc/src/java/macromedia/asc/parser/Tokens.java
flex/sdk/trunk/modules/asc/test/compiler/as3/Definitions/Classes/ClassDef/ClassKeywordErr .err
flex/sdk/trunk/modules/asc/test/compiler/as3/Definitions/Function/EmptyNameErr18.err
flex/sdk/trunk/modules/asc/test/compiler/as3/Definitions/Function/EmptyNameErr2.err
flex/sdk/trunk/modules/asc/test/compiler/as3/Definitions/Function/EmptyNameErr74.err
flex/sdk/trunk/modules/asc/test/compiler/as3/Definitions/Function/FreeFloatingFuncBodyErr .err
flex/sdk/trunk/modules/asc/test/compiler/as3/Definitions/Function/StaticNameErr18.err
flex/sdk/trunk/modules/asc/test/compiler/as3/Definitions/Function/StaticNameErr2.err
flex/sdk/trunk/modules/asc/test/compiler/as3/Definitions/Function/StaticNameErr74.err
flex/sdk/trunk/modules/asc/test/compiler/as3/Definitions/Function/StaticPublicNameErr18.e rr
flex/sdk/trunk/modules/asc/test/compiler/as3/Definitions/Function/StaticPublicNameErr2.er r
flex/sdk/trunk/modules/asc/test/compiler/as3/Definitions/Function/StaticPublicNameErr23.e rr
flex/sdk/trunk/modules/asc/test/compiler/as3/Definitions/Function/StaticPublicNameErr74.e rr
flex/sdk/trunk/modules/asc/test/compiler/as3/Definitions/Function/ThreeOptArgFunctionErr2 .err
flex/sdk/trunk/modules/asc/test/compiler/as3/Definitions/FunctionAccessors/EmptyNameErr17 .err
flex/sdk/trunk/modules/asc/test/compiler/as3/Definitions/FunctionAccessors/EmptyNameErr18 .err
flex/sdk/trunk/modules/asc/test/compiler/as3/Definitions/FunctionAccessors/EmptyNameErr2. err
flex/sdk/trunk/modules/asc/test/compiler/as3/Definitions/FunctionAccessors/EmptyNameErr23 .err
flex/sdk/trunk/modules/asc/test/compiler/as3/Definitions/FunctionAccessors/EmptyNameErr36 .err
flex/sdk/trunk/modules/asc/test/compiler/as3/Definitions/FunctionAccessors/EmptyNameErr38 .err
flex/sdk/trunk/modules/asc/test/compiler/as3/Definitions/FunctionAccessors/EmptyNameErr40 .err
flex/sdk/trunk/modules/asc/test/compiler/as3/Definitions/FunctionAccessors/EmptyNameErr41 .err
flex/sdk/trunk/modules/asc/test/compiler/as3/Definitions/FunctionAccessors/EmptyNameErr42 .err
flex/sdk/trunk/modules/asc/test/compiler/as3/Definitions/FunctionAccessors/EmptyNameErr44 .err
flex/sdk/trunk/modules/asc/test/compiler/as3/Definitions/FunctionAccessors/EmptyNameErr45 .err
flex/sdk/trunk/modules/asc/test/compiler/as3/Definitions/FunctionAccessors/EmptyNameErr46 .err
flex/sdk/trunk/modules/asc/test/compiler/as3/Definitions/FunctionAccessors/EmptyNameErr47 .err
flex/sdk/trunk/modules/asc/test/compiler/as3/Definitions/FunctionAccessors/EmptyNameErr50 .err
flex/sdk/trunk/modules/asc/test/compiler/as3/Definitions/FunctionAccessors/EmptyNameErr52 .err
flex/sdk/trunk/modules/asc/test/compiler/as3/Definitions/FunctionAccessors/EmptyNameErr53 .err
flex/sdk/trunk/modules/asc/test/compiler/as3/Definitions/FunctionAccessors/EmptyNameErr54 .err
flex/sdk/trunk/modules/asc/test/compiler/as3/Definitions/FunctionAccessors/EmptyNameErr55 .err
flex/sdk/trunk/modules/asc/test/compiler/as3/Definitions/FunctionAccessors/EmptyNameErr56 .err
flex/sdk/trunk/modules/asc/test/compiler/as3/Definitions/FunctionAccessors/EmptyNameErr57 .err
flex/sdk/trunk/modules/asc/test/compiler/as3/Definitions/FunctionAccessors/EmptyNameErr58 .err
flex/sdk/trunk/modules/asc/test/compiler/as3/Definitions/FunctionAccessors/EmptyNameErr59 .err
flex/sdk/trunk/modules/asc/test/compiler/as3/Definitions/FunctionAccessors/EmptyNameErr60 .err
flex/sdk/trunk/modules/asc/test/compiler/as3/Definitions/FunctionAccessors/EmptyNameErr61 .err
flex/sdk/trunk/modules/asc/test/compiler/as3/Definitions/FunctionAccessors/EmptyNameErr62 .err
flex/sdk/trunk/modules/asc/test/compiler/as3/Definitions/FunctionAccessors/EmptyNameErr64 .err
flex/sdk/trunk/modules/asc/test/compiler/as3/Definitions/FunctionAccessors/EmptyNameErr65 .err
flex/sdk/trunk/modules/asc/test/compiler/as3/Definitions/FunctionAccessors/EmptyNameErr66 .err
flex/sdk/trunk/modules/asc/test/compiler/as3/Definitions/FunctionAccessors/EmptyNameErr68 .err
flex/sdk/trunk/modules/asc/test/compiler/as3/Definitions/FunctionAccessors/EmptyNameErr69 .err
flex/sdk/trunk/modules/asc/test/compiler/as3/Definitions/FunctionAccessors/EmptyNameErr70 .err
flex/sdk/trunk/modules/asc/test/compiler/as3/Definitions/FunctionAccessors/EmptyNameErr71 .err
flex/sdk/trunk/modules/asc/test/compiler/as3/Definitions/FunctionAccessors/EmptyNameErr72 .err
flex/sdk/trunk/modules/asc/test/compiler/as3/Definitions/FunctionAccessors/EmptyNameErr73 .err
flex/sdk/trunk/modules/asc/test/compiler/as3/Definitions/FunctionAccessors/EmptyNameErr74 .err
flex/sdk/trunk/modules/asc/test/compiler/as3/Definitions/Packages/NamespacePackageErr.err
flex/sdk/trunk/modules/asc/test/compiler/as3/Definitions/Packages/PackageNameAtErr.err
flex/sdk/trunk/modules/asc/test/compiler/as3/Definitions/Packages/ReturnInPackageErr.err
flex/sdk/trunk/modules/asc/test/compiler/as3/Definitions/const/ConstAsFunctionArgErr.err
flex/sdk/trunk/modules/asc/test/compiler/as3/Definitions/const/ConstRedefineErr.err
flex/sdk/trunk/modules/asc/test/compiler/as3/Directives/Attributes/CTA/IllegalErr.err
flex/sdk/trunk/modules/asc/test/compiler/as3/Directives/usenamespace/IllegalIdentifiersAt Err.err
flex/sdk/trunk/modules/asc/test/compiler/as3/Directives/usenamespace/IllegalIdentifiersIl legalCharErr.err
flex/sdk/trunk/modules/asc/test/compiler/as3/Expressions/isOperator/isOpMissingValueErr.e rr
flex/sdk/trunk/modules/asc/test/compiler/as3/LocalizedErrors/1038-BreakTargetNotFound.err
flex/sdk/trunk/modules/asc/test/compiler/as3/LocalizedErrors/1039-ContinueTargetNotFound. err
flex/sdk/trunk/modules/asc/test/compiler/as3/LocalizedErrors/1051-ReturnInVoidMethod.err
flex/sdk/trunk/modules/asc/test/compiler/as3/LocalizedErrors/1084-ExpectTokenBeforeErr.er r
flex/sdk/trunk/modules/asc/test/compiler/as3/LocalizedErrors/1149-ReturnErr.err
flex/sdk/trunk/modules/asc/test/compiler/as3/LocalizedErrors/1159-ReturnInPackageErr.err
flex/sdk/trunk/modules/asc/test/compiler/as3/LocalizedErrors/1177-ReturnInGlobalErr.err
flex/sdk/trunk/modules/asc/test/compiler/as3/LocalizedErrors/1190-BaseClassNotCTCErr.err
flex/sdk/trunk/modules/asc/test/compiler/as3/LocalizedErrors/1196-NoExpressionAfterThrow. err
flex/sdk/trunk/modules/asc/test/compiler/bugs/ASC-1638.err
flex/sdk/trunk/modules/asc/test/compiler/bugs/ASC-3250.err
flex/sdk/trunk/modules/asc/test/compiler/ecma3/e10_1_4_3_Err.err
flex/sdk/trunk/modules/asc/test/compiler/ecma3/e10_1_4_4_Err.err
flex/sdk/trunk/modules/asc/test/compiler/ecma3/e10_1_4_5_Err.err
flex/sdk/trunk/modules/asc/test/compiler/ecma3/e10_1_4_6_Err.err
flex/sdk/trunk/modules/asc/test/compiler/ecma3/e10_1_4_7_Err.err
flex/sdk/trunk/modules/asc/test/compiler/ecma3/e12_8_1_Err.err
flex/sdk/trunk/modules/asc/test/compiler/ecma3/e12_9_1_Err.err
flex/sdk/trunk/modules/asc/test/compiler/ecma3/e7_3_13_Err.err
flex/sdk/trunk/modules/asc/test/compiler/ecma3/e7_5_8_Err.err
flex/sdk/trunk/modules/asc/test/compiler/ecma3/e7_8_3_Err.err
flex/sdk/trunk/modules/asc/test/compiler/ecma3/e7_8_4_Err.err
flex/sdk/trunk/modules/asc/test/compiler/es4/conditionalcompilation/nonExistantConfigVar. err
flex/sdk/trunk/modules/asc/test/compiler/testconfig.txt
