0 Replies Latest reply on Jun 11, 2009 1:03 AM by rfrishbe
    [svn:fx-trunk] 7740: Make sure to push down muted property in VolumeBar to muteButton.
    rfrishbe Level 3
      Revision: 7740
      Author:   rfrishbe@adobe.com
      Date:     2009-06-11 01:03:46 -0700 (Thu, 11 Jun 2009)
      Log Message:
      Also, change MUTED_CHANGE to only dispatch when the muted property changes based on user-interaction (based on being pushed down from videoplayer).
      Fix PopUpAnchor TODO around closing the popup when removing the popup from the stage.
      QE Notes: -
      Doc Notes: -
      Bugs: SDK-21727
      Reviewer: Chiedo
      tests: checkintest (seem to fail due to local changes to ScrollBar, which I'm not checking in here)
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-21727
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/PopUpAnchor.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/mediaClasses/MuteButton.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/mediaClasses/VolumeBar.as
