0 Replies Latest reply on Jun 11, 2009 6:53 AM by CoreyRLucier
    [svn:fx-trunk] 7743: Moving away from using namespace qualifiers in most cases in the SDK.
    CoreyRLucier Adobe Employee
      Revision: 7743
      Author:   clucier@adobe.com
      Date:     2009-06-11 06:53:10 -0700 (Thu, 11 Jun 2009)
      Log Message:
      Moving away from using namespace qualifiers in most cases in the SDK.  We've run into a few cases now where the use of qualifiers in code that is called excessively can slow things down.
      Bugs: SDK-21337
      Reviewer: Ryan, Paul
      QE Notes: None
      Tests: Ran several random Mustella test groups, checkintests.
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-21337
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/airframework/src/mx/controls/FlexNativeMenu.as
          flex/sdk/trunk/frameworks/projects/airframework/src/mx/controls/HTML.as
          flex/sdk/trunk/frameworks/projects/airframework/src/mx/controls/fileSystemClasses/FileSys temDataGridNameColumnRenderer.as
          flex/sdk/trunk/frameworks/projects/airframework/src/mx/managers/WindowedSystemChildrenLis t.as
          flex/sdk/trunk/frameworks/projects/airframework/src/mx/managers/WindowedSystemRawChildren List.as
          flex/sdk/trunk/frameworks/projects/airframework/src/spark/components/Window.as
          flex/sdk/trunk/frameworks/projects/airframework/src/spark/components/WindowedApplication. as
          flex/sdk/trunk/frameworks/projects/airframework/src/spark/components/windowClasses/TitleB ar.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/Application.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/ButtonBarButton.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/DataGroup.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/DropDownList.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/Group.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/RadioButton.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/RadioButtonGroup.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/SkinnableContainer.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/VideoPlayer.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/supportClasses/DropDownCont roller.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/supportClasses/ItemRenderer .as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/supportClasses/ListBase.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/supportClasses/SkinnableCom ponent.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/supportClasses/Slider.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/core/SpriteVisualElement.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/AddAction.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/AnimateTransform.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/MotionPath.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/supportClasses/AddActionInstan ce.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/supportClasses/AnimateTransfor mInstance.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/supportClasses/RemoveActionIns tance.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/effects/supportClasses/SetActionInstan ce.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/primitives/supportClasses/GraphicEleme nt.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/default/ErrorSkin.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/skins/default/FocusSkin.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/collections/ModifiedCollectionView.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/containers/Form.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/containers/FormItem.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/containers/GridRow.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/containers/HBox.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/containers/HDividedBox.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/containers/TitleWindow.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/containers/VBox.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/containers/utilityClasses/CanvasLayou t.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/containers/utilityClasses/ConstraintC olumn.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/containers/utilityClasses/ConstraintR ow.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/PopUpButton.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/Tree.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/dataGridClasses/DataGridColu mn.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/dataGridClasses/DataGridItem Renderer.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/listClasses/ListBase.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/textClasses/TextRange.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/treeClasses/DefaultDataDescr iptor.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/treeClasses/HierarchicalColl ectionView.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/Application.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/Container.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/UIComponentGlobals.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/effects/AddChildAction.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/effects/CompositeEffect.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/effects/Dissolve.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/effects/Effect.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/effects/EffectInstance.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/effects/EffectManager.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/effects/MaskEffect.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/effects/effectClasses/ActionEffectIns tance.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/effects/effectClasses/AddChildActionI nstance.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/effects/effectClasses/AnimateProperty Instance.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/effects/effectClasses/CompositeEffect Instance.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/effects/effectClasses/DissolveInstanc e.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/effects/effectClasses/FadeInstance.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/effects/effectClasses/MaskEffectInsta nce.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/effects/effectClasses/MoveInstance.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/effects/effectClasses/RemoveChildActi onInstance.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/effects/effectClasses/SetPropertyActi onInstance.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/effects/effectClasses/SetStyleActionI nstance.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/effects/effectClasses/SoundEffectInst ance.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/effects/effectClasses/TweenEffectInst ance.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/effects/effectClasses/ZoomInstance.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/formatters/DateFormatter.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/graphics/GradientBase.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/graphics/GradientStroke.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/graphics/LinearGradient.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/graphics/RadialGradient.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/graphics/RadialGradientStroke.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/InitLocalConnection.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/MainLocalConnection.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/SystemChildrenList.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/SystemRawChildrenList.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/dragClasses/DragProxy.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/marshalClasses/MarshalPopUpD ata.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/systemClasses/MarshallPlan.a s
          flex/sdk/trunk/frameworks/projects/framework/src/mx/preloaders/Preloader.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/resources/ResourceBundle.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/resources/ResourceManagerImpl.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/skins/halo/DateChooserIndicator.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/skins/halo/PanelSkin.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/skins/halo/PopUpButtonSkin.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/skins/halo/PopUpIcon.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/skins/halo/PopUpMenuIcon.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/skins/halo/SwatchSkin.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/states/RemoveChild.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/styles/CSSStyleDeclaration.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/styles/StyleProtoChain.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/utils/LoaderUtil.as
          flex/sdk/trunk/frameworks/projects/framework_textLayout/src/mx/controls/dataGridClasses/T LFDataGridItemRenderer.as
          flex/sdk/trunk/frameworks/projects/rpc/src/mx/messaging/ChannelSet.as
          flex/sdk/trunk/frameworks/projects/rpc/src/mx/rpc/remoting/Operation.as
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/css/StyleModule.vm
