6 Replies Latest reply on Jun 11, 2009 7:58 AM by Graphic Graeme
    AS2 XML Flash Navigation
    Graphic Graeme
      Hello All,
      I have been creating a dynamic Flash Navigation based on a tutorial I found online.
      I'm having issues aligning the MovieClip house all the array names from My XML file.
      I'm using:
      var yPosition:Number = 118;
      var xPosition:Number = 250;
      to align the Movie Clip. For some reason I can adjust the yPosition but I cant get the xPosition to move my MovieClip at all. >:(
      Any helpful hints would be greatly appreciated.
      Cheers-
      Graeme
        • 1. Re: AS2 XML Flash Navigation
          The code you offered may establish the values you want for alignment, but it won't align anything.  What code are you trying to use to align things?
          • 2. Re: AS2 XML Flash Navigation
            DazFaz Level 1
            Need more coding information really to see where you are using these vars.
            • 3. Re: AS2 XML Flash Navigation
              Graphic Graeme Level 1
              Heres the code I'm using:
              //Store Button Position
              //Declare New XML Object
              var myXML:XML = new XML();
              //Set Flash to ignore the XML file's white space
              myXML.ignoreWhite = true;
              //Declare new Array to store the links from the XML file
              var links:Array = new Array();
              //Declare new Array to store the names from the XML file
              var names:Array = new Array();
              //Set XML onLoad function
              myXML.onLoad = function(){
                  //Set varible to store the XML childNodes
                  //This allows you to get the number of buttons in the XML file.
                  //You'll use this tell flash how many times to loop the for loop.
                  var linkname:Array = this.firstChild.childNodes;
                  //Set a for loop
                  for(i=0;i<linkname.length;i++){
                      //Push the button name into the names Array
                      names.push(linkname[i].attributes.NAME);
                      //Push the button link into the links Array
                      links.push(linkname[i].attributes.LINK);
                      //Attach the button Movie Clip from the libray give it an instance name and place it on the next highest level
                      _root.attachMovie("button","btn"+i,_root.getNextHighestDepth());
                      //Set the y position of the buttons
                      _root["btn"+i]._y = yPosition;
                      //Increace the varible yPosition 15 pixel each time the loop runs to place each button under each other
                      yPosition = yPosition+25;
                      //Place the button name from names Array into the blackTxt text box
                      _root["btn"+(i)].blackTxt.Txt.text = (names[i]);
                      //Place the button name from names Array into the whiteTxt text box
                      _root["btn"+(i)].whiteTxt.Txt.text = (names[i]);
                      //Assign the btnOver function to the button onRollOver state.
                      _root["btn"+(i)].onRollOver = btnOver;
                      //Assign the btnOut function to the button onRollOut state.
                      _root["btn"+(i)].onRollOut = btnOut;
                      //Assign the btnRelease function to the button onRelease state.
                      _root["btn"+(i)].onRelease = btnRelease;
              //Load the XML file
              myXML.load("links.xml");
              //Button Over function
              function btnOver(){
                  //This referse to the current button the mouse is over
                  //Go To And Stop frame 2 of the current button the mouse is over
                  this.gotoAndStop(2);
              //Button Out function
              function btnOut(){
                  //Go To And Stop frame 3 of the current button the mouse rolls out from
                  this.gotoAndStop(3);
              //Button Release function
              function btnRelease(){
                  //Set a varible named currentBtn equal to the instance name of the current button the mouse clicked on
                  var currentBtn:String = this._name;
                  //Set a varible named currentIndex equal to the varible currentBtn and the characters between 3rd letter and 5th of that string.
                  //This will return a number between 0 and the total number of buttons
                  var currentIndex:String = currentBtn.substring(3,5);
                  //Get the URL from the links Array
                  //Use the currentIndex varible as the index number
                  getURL(links[currentIndex]);
              • 4. Re: AS2 XML Flash Navigation
                DazFaz Level 1
                Ive just taken a very quick look through your code and I cannot find where you are using "xPosition" to move your movieClip along the X axis. Might this be the problem?
                • 5. Re: AS2 XML Flash Navigation
                  Daz nailed it... I let a text editor do a detailed check and the xPosition doesn't exist beyond being declared/initialized.
                  • 6. Re: AS2 XML Flash Navigation
                    Perfect! That totally did it
                    WooHoo, It works
                    Thanks A million
                    Cheers-
                    Graeme
