1 Reply Latest reply on Jun 11, 2009 11:45 AM by Graphic Graeme
    Hiding XML infomation
    Graphic Graeme Level 1
      I have created a dynamic accordion style navigation button using both Falsh and XML.
      I have the XML loading at a certain keyframe after the navigation button is fully expanded
      creating 7 sub navigation buttons which link to a certain website.
      The Issue I'm having is when the user rolls off the button the it collaspes but the 7 sub navigation buttons still remain.
      I'll attach the code to claify:
      //Store Button Position
      var yPosition:Number = 210;
      var xPosition:Number = 110;
      //Declare New XML Object
      var myXML:XML = new XML();
      //Set Flash to ignore the XML file's white space
      myXML.ignoreWhite = true;
      //Declare new Array to store the links from the XML file
      var links:Array = new Array();
      //Declare new Array to store the names from the XML file
      var names:Array = new Array();
      //Set XML onLoad function
      myXML.onLoad = function(){
          //Set varible to store the XML childNodes
          //This allows you to get the number of buttons in the XML file.
          //You'll use this tell flash how many times to loop the for loop.
          var linkname:Array = this.firstChild.childNodes;
          //Set a for loop
          for(i=0;i<linkname.length;i++){
              //Push the button name into the names Array
              names.push(linkname[i].attributes.NAME);
              //Push the button link into the links Array
              links.push(linkname[i].attributes.LINK);
              //Attach the button Movie Clip from the libray give it an instance name and place it on the next highest level
              _root.attachMovie("button","btn"+i,_root.getNextHighestDepth());
              //Set the y position of the buttons
              _root["btn"+i]._x = xPosition;
              //Increace the varible yPosition 15 pixel each time the loop runs to place each button under each other
              xPosition = xPosition+0
              _root["btn"+i]._y = yPosition;
              yPosition = yPosition+30;
              //Place the button name from names Array into the blackTxt text box
              _root["btn"+(i)].blackTxt.Txt.text = (names[i]);
              //Place the button name from names Array into the whiteTxt text box
              _root["btn"+(i)].whiteTxt.Txt.text = (names[i]);
              //Assign the btnOver function to the button onRollOver state.
              _root["btn"+(i)].onRollOver = btnOver;
              //Assign the btnOut function to the button onRollOut state.
              _root["btn"+(i)].onRollOut = btnOut;
              //Assign the btnRelease function to the button onRelease state.
              _root["btn"+(i)].onRelease = btnRelease;
      //Load the XML file
      myXML.load("links.xml");
      //Button Over function
      function btnOver(){
          //This referse to the current button the mouse is over
          //Go To And Stop frame 2 of the current button the mouse is over
          this.gotoAndStop(2);
      //Button Out function
      function btnOut(){
          //Go To And Stop frame 3 of the current button the mouse rolls out from
          this.gotoAndStop(3);
      //Button Release function
      function btnRelease(){
          //Set a varible named currentBtn equal to the instance name of the current button the mouse clicked on
          var currentBtn:String = this._name;
          //Set a varible named currentIndex equal to the varible currentBtn and the characters between 3rd letter and 5th of that string.
          //This will return a number between 0 and the total number of buttons
          var currentIndex:String = currentBtn.substring(3,5);
          //Get the URL from the links Array
          //Use the currentIndex varible as the index number
          getURL(links[currentIndex]);
