5 Replies Latest reply on Jun 12, 2009 1:18 AM by SilverFox64
    Transfering data between cascading popups
    curtisa2
      Is it possible to pass data between multiple cascading popups ? I know how to pass back to the parentApplication but not the parentPopUp so-to-speak.
      The setup I have is that my parent application tiggers a popup (say PopUp A) and that in turn triggers another popup (PopUp B). I want to pass the results of the calculations done in popup B back to popup A. (The popups are all in separate .mxml files).
      Can this be done easily ?
      Alex
        • 1. Re: Transfering data between cascading popups
          *Prashant Shelke* Level 4
          See following structure:
          Main Application
                    --> PopUp A (it has, var parent:Object; before popping up A you can set popUpA.parent = this; )                // here this is Main Application
                               -->    PopUp B (it has, var parent:Object; before popping up B you can set popUpB.parent = this; )          // here this is PopUpA
          So after making calculation you can set it to any variable or control on its parent.
          Thanks.
          • 2. Re: Transfering data between cascading popups
            curtisa2 Level 1
            I thought that was what I had ... namely,
            In mainApp.mxml ...
                        private var popUpA:IFlexDisplayObject;
                        popUpA = PopUpManager.createPopUp(this, popUpAmxmlFile, true);
                        PopUpManager.centerPopUp(popUpA);
            then in popup A ...
                           popUpB = PopUpManager.createPopUp(this, popUpBmxmlFile, true);
                           PopUpManager.centerPopUp(popUpB);
            But then in popup B the line ...
                           parentApplication.myPublicFn();
            causes the app to look for 'myPublicFn' in the mainApp, not popup A
            Is my logic messed up ?
            Thanks for the help
            • 3. Re: Transfering data between cascading popups
              leybniz Level 4
              Best solution for your difficulty from the root - would be  to store all calculation results, all data model in one spot/place say using some
              singleton class, which you could access then from anywhere in the code.
                   public class CentralModelLocator {
                        private static var instance : CentralModelLocator;
                        public var anyData:*;
                        function CentralModelLocator() {
                             if (instance) {
                                  throw new Error(
                                       'Singleton already created',
                                       getQualifiedClassName(this));
                             instance = this;
                        public static function getInstance():CentralModelLocator {
                             if (!instance)
                                  instance = new CentralModelLocator();
                             return instance;
              Then you could access your data from any popup of any depth, just use this code:
              Inside PopupA code write to this var
              CentralModelLocator.getInstance().anyData = 'Some calculation result';
              Inside PopupB use this one code to get the result:
              • 4. Re: Transfering data between cascading popups
                parentApplication will referr to the main Application context. You can try by storting this of Parent --> Child1 --> Child2 ..so on, as shown in previous flow, this will work for u.
                • 5. Re: Transfering data between cascading popups
                  SilverFox64
                  I have this scenario in the project I am currently working on. The solution I used was to add an event listener to PopUpB when creating it in PopUpA:
                  var popUpB:PopUpB = PopUpB(PopUpManager.createPopUp(this, PopUpB, true, null));
                  popUpB.addEventListener(DataEvent.TYPE, eventHandlerFunction,false,0,true);
                  The DataEvent is a user defined Event and contains the data required by PopUpA.
                  All I have to do then is dispatch the event along with the data from PopUpB.
                  dispatchEvent(new DataEvent(dataRequired, DataEvent.TYPE, true, false));
