8 Replies Latest reply on Jun 11, 2009 5:09 PM by Ned Murphy
    Nested MovieClips
    GumpsterF Level 1
      I have a problem that I think is a simple one but I cannot seem to figure it out, and it has been 2 days of fighting wiht it so I am here to plea for help from the collective experts. Here is the issue.
      I have created a movieClip which is just a rectangle shape that has an interior timeline which object tweens from a 2x200 pixel to a 200x200 pixel shape.
      This movieClip has an instance name of menu_2.
      After the tween happens inside menu_2, on the stop(); frame I have placed another movieClip with an instance name of mi_1. This clip is 100 x 35 pixels and site floating inside the menu_2 MovieClip. Inside this movieClip there is a timeline where there are a "the_start" and a "the_end" label on either end of the timeline each with stop(); comands and some graphics which change opacity.
      What I cannot seem to get to happen is to activate the timeline inside the mi_1 MovieClip. What I would like to happen is that when the user mouses over the mi_1 movieClip, it triggers a number of events, along with triggering playing the timeline inside of mi_2.
      Here is the code I have tried on the main (scene 1) timeline. None of which have worked.
      menu_2.mi_1.onRollOver = function() {
           menu_2.mi_1.gotoAndStop("the_end");
      menu_2.onRollOver = function() {
      this. mi_1.play();
      Here is the code I have tried inside the menu_2 MovieClip on the same frame as the mi_1 has been placed;
      this.onRollOver = function() {
           this.gotoAndStop("the_end");
      Nothing seems to be working.
      I'll send anyone the FLA willing to help...
      Help!
      Forrest
        • 1. Re: Nested MovieClips
          If mi_1 lives down the timeline on menu_2, the code that you have on the main timeline cannot communicate with it because it doesn't exist when that code executes.  Try moving the mi_1 code down to the stop frame inside menu_2.
          Another option would be to have mi_1 invisible up until that stop frame, and at the stop frame make it visible.  That way, it would be site of the main timeline code.
          • 2. Re: Nested MovieClips
            GumpsterF Level 1
            Hi Ned.
            I have tried option 1, with no luck. Maybe I had the wrong code? I posted three different code attempts for your option 1 in my original post.
            If I am to try option 2 that you suggest, I think I understand how to make the mc invisible, mi_1.visible = false; ?
            What would be the correct code on the mail timeline to trigger events inside mi_1?
            Ned, may I send you this FLA, just to look at not to fix for me?
            Forrest
            • 3. Re: Nested MovieClips
              In the first frame inside the menu_2 movieclip you would have:
              mi_1._visible = false;
              and mi_1 would need to extend all the way back to frame 1
              When you get to the point where it would appear, you would use
              mi_1._visible = true;
              • 4. Re: Nested MovieClips
                GumpsterF Level 1
                Fair enough, I understand that, but then how do I get (and what code do I use) to execute the timeline inside of the mi_1 mc using a onRollOver command on the main timeline?
                • 5. Re: Nested MovieClips
                  The first one shown should do the trick if what I understand the scenario to be is correct:
                  • 6. Re: Nested MovieClips
                    GumpsterF Level 1
                    That's what I thought too Ned. All the reseach I did, tells me that is how you access a nested movieClip in another MovieClip.
                    Your visible code works as it should, but I still cannot get the nested MovieClip to be affected by a call to action on the main timeline.
                    Did not do anything. I would have just used a button with roll over effects, but a button also seems to be masked inside the menu_2 mc.
                    aarrrg.
                    • 7. Re: Nested MovieClips
                      GumpsterF Level 1
                      On second inspection Ned, your advice was spot on. I made a new Movie, very simple and it works fine.
                      I think my problem was when the menu_2 m appeared on the stage as opposed to when the code appeared.
                      I just need to simplify my movie I think and start again.
                      Thanks for the help and making me think about it.
                      Cheers
                      Forrest
                      • 8. Re: Nested MovieClips
                        You're welcome Forrest.  That's a key thing to remember, though it's easy to overlook at times... things have to be in the presence of code that is talking to them.
