This content has been marked as final.
Show 1 reply
1. Re: White line streaked with red lines at bottom of a clip = ???
Adolfo Rozenfeld Jun 11, 2009 7:59 PM (in response to Frédéric Leclair)If it is what I think it is, you applied a reverse speed setting to that clip in Premiere Pro. Quite amazingly, slow/fast/reverse speed settings in video clips are translated into After Effects equivalents when you import a project from Premiere Pro.
To check if this is the case, select the layer and go to Layer > Time > Time Stretch. It should show a negative percentage (like -50 %), ie reverse motion.
Did I guess correctly?
Christmas sugar cane is a rather poetic way of picturing it!
