3 Replies Latest reply on Sep 22, 2008 2:33 AM by Peter Grainge
    Chapter Numbers incorrect
    Pambear
      I created a test project with one topic "TopicA". The topic is not tagged. Then I created 2 books and placed "TopicA" in both books. I tagged one book's TOC as "User1" and the other book's TOC as "User2".
      When I generate the Flash version, for User1, the correct book displays. But when I generate the Printed version, both books display....the same with User2.
      So I have to create a duplicate of TopicA and tag one as "User1" and the other as "User2" before placing under their respective books. Then all works fine?
      Is there an easier way?
      Pam
        • 1. Re: Chapter Numbers incorrect
          I created a one topic project. Two books in the TOC, both having the one topic in. Created a printed document. It showed both books and the topic was in twice.
          Is that not what you want?
          • 2. Re: Chapter Numbers incorrect
            Pambear Level 1
            Peter, the problem I'm having is getting the same sequential Chapter Number (assigned to Books on the TOC) in the Printed Version as I do in the Flash Version. In essence, does assigning a build tag to a TOC (as opposed to the topic itself) not apply when creating a Print version?
            Here is how the project is set up:
            1 topic
            2 build tags (mutually exclusive)
            4 SSLs (Flash version and Print version to display each build tag). Each Flash and Print SSL excludes the other FLash and Print SSL.
            2 Books on TOC each containing the one topic
            Now, right click on each BOOK and apply a build tag (do not apply the build tag to the Properties of the topic).
            Generate a Flash SSL and the related Print SSL and notice the difference in the TOC:
            The Flash version will contain one TOC and one topic.(RIGHT!)
            The Print version will contain 2 TOCs and with the same topic listed under each. (WRONG!)
            It's really difficult to explain without images...If you saw it, you'd understand immediately!
            Thanks for your help!
            Pam
            • 3. Re: Chapter Numbers incorrect
              So post some screenshots somewhere!
              Google - share photos
