2 Replies Latest reply on Jun 12, 2009 2:12 PM by ahmed.malik
    Adobe Air Problem with SQL Lite
    ahmed.malik
      Hi
      I am facing a strange, weired error.. and i am hating it
      SQLError: 'Error #3132: Data type mismatch.', details:'could not convert text value to numeric value.', operation:'execute', detailID:'2300'
      here is my code:
      stmt = new SQLStatement();
      stmt.text = "UPDATE PracticeTable SET UserAnswer=:userAnswer, TimeTaken=:timeTaken WHERE Primarykey=:primaryKey";
      stmt.parameters[":userAnswer"] = "C";
      stmt.parameters[":timeTaken"] = "10";
      stmt.parameters[":primaryKey"] = 141;
      stmt.sqlConnection = MySQLConnection.Instance.Connection;
      stmt.execute();
      following is my table
      CREATE TABLE "PracticeTable" ("PrimaryKey" INTEGER PRIMARY KEY  AUTOINCREMENT  NOT NULL  , "CategoryName" VARCHAR NOT NULL , "QuestionHTMLName" VARCHAR NOT NULL , "AnswerHTMLName" VARCHAR, "AnswerCorrectOption" VARCHAR, "NoOfOptions" INTEGER, "UserAnswer" VARCHAR, "TimeTaken" VARCHAR, "StatusOfAnswer" VARCHAR, "BookMark" VARCHAR, "RCJoin" VARCHAR DEFAULT 0, "SyncFlage" INTEGER NOT NULL  DEFAULT 0)
      I really can't figure out what's wrong, please someone helppppp !!!!
      Best regards,
      Ahmed.
        • 1. Re: Adobe Air Problem with SQL Lite
          jbenson@oper8 Level 2
          I'd try simplyfying my statement a bit and see if you still have the issue.  Perhaps your parameters are just not being interpreted as the right datatype before being executed
          var myParams = {userAnswer: "C", timeTaken: "10", primaryKey:141};
          stmt.text = "UPDATE PracticeTable SET UserAnswer='" + myParams.userAnswer + "', TimeTaken='" + myParams.timeTaken + "' WHERE Primarykey=" + myParams.primaryKey;
          stmt.execute();
          • 2. Re: Adobe Air Problem with SQL Lite
            ahmed.malik Level 1
            Hi Jason
            Thanks for replying. There was a problem with default value in column
            SyncFlage. I removed and then added the mentioned column again. Now it works
            like a charm.
            Best regards,
            Ahmed.
