5 Replies Latest reply on Jun 14, 2009 9:20 AM by Foxchx
    new project from source code
    Foxchx Level 1
      I am trying to install a new project from a source code i have my problem is that i want to change the names but i don't understand flex builder on that level.
      I guess my workflow is wrong because usually i create multiple instances of a project so that when i mess it up, i can continue on another instance but because i don't understand the naming policy of Flexbuilder, i never manage to create another instance of the same project!?
        • 1. Re: new project from source code
          Michael Borbor Level 4
          You can use F2 to refactor your app, I really don't understand what you mean
          by flex naming policy.
          • 2. Re: new project from source code
            Benji2008 Level 1
            I guess you want the give the new project the same name ? but that is never possible
            • 3. Re: new project from source code
              Foxchx Level 1
              i just need a little reassuring on the way to understand that part (well flex as a lot of these little parts without explanation but that's one that really bug me)
              When using flex builder i need to create a project....Oh!, no wait, I need to create a workspace! then a project then decide on many little settings...
              THe SQL databse end up somewhere like [C:\Users\user\AppData\Roaming\crazyflexapp\Local Store]
              My work space is say [P:\@AIRFLEX\_workspace\crazyflexapp\]
              My AiR app install say [C:\ProgramFiles\AIR Examples\Exercise\crazyflexapp\]
              It's all a bit confusing don't you think, especially if there's a program (FlexBuilder3) That don't allow duplicate of name?
              And because i am starting i  am using existing source code, so i never know if i need to addapt and MXML code because it might refer to the wrong folder name or location?!
              Is there a blog anywhere giving the answer to all that in a nice little comprensive explanation?\
              thanks
              • 4. Re: new project from source code
                Change the source path. In the Project properties.
                • 5. Re: new project from source code
                  Foxchx Level 1
                  Well i was just pointing out the complexity of it all... here's a visual of what i don'tv really understand
                  Now you seem to be saying that i just need to change the sourcepath and that would fix my problems!?!?
                  I don't see how i can change the name of a project to fit the source code i have....
                  Actually i tried manyways but nothing work....
                  I can make the source code work but only if use the same names as the SC was made under...
                  (for the record, i am using the source code from the adobe employee directory)
