1 Reply Latest reply on Jun 12, 2009 4:56 AM by Hodmi
    Problem using axis in a component
    christoph.thodte
      Hello,
      I develop my own component for deploying the LC. The component uses axis as a client for a webservice to get information from a other server. My component contains the axis.jar and it is described in the component.xml too.
      When I start my process which contains my component I get the following error:
      java.io.InvalidClassException: javax.xml.namespace.QName; local class incompatible: stream classdesc serialVersionUID = 4418622981026545151, local class serialVersionUID = -9120448754896609940
                      at com.adobe.idp.dsc.provider.impl.base.AbstractResponseHolder.handleException(AbstractRespo nseHolder.java:161)
                      at com.adobe.idp.dsc.provider.impl.soap.axis.sdk.SoapSdkBindingStubUtil.deSerializeResponse( SoapSdkBindingStubUtil.java:122)
                      at com.adobe.idp.dsc.provider.impl.soap.axis.sdk.SoapAxisDispatcher.doSend(SoapAxisDispatche r.java:128)
                      at com.adobe.idp.dsc.provider.impl.base.AbstractMessageDispatcher.send(AbstractMessageDispat cher.java:57)
                      at com.adobe.idp.dsc.clientsdk.ServiceClient.invoke(ServiceClient.java:208)
                      at com.adobe.common.utils.invoke.InvokeWithProgressRunner.invokeServiceOperation(InvokeWithP rogressRunner.java:170)
                      at com.adobe.common.utils.invoke.InvokeWithProgressRunner.run(InvokeWithProgressRunner.java: 97)
                      at org.eclipse.jface.operation.ModalContext$ModalContextThread.run(ModalContext.java:113)
      Caused by: java.io.InvalidClassException: javax.xml.namespace.QName; local class incompatible: stream classdesc serialVersionUID = 4418622981026545151, local class serialVersionUID = -9120448754896609940
      I think there are different versions of the class QName. How can I resolve the problem? Can somebody help me?
      Christoph
        • 1. Re: Problem using axis in a component
          Hodmi Level 4
          The problem is that the axis jar files are already in the app server's lib path.  By including the jar in your component you are getting a conflict - this can also cause some weird coersion errors.
          Fortunately the solution is quite simple.  Remove the axis jar files from your component and use the <import-packages> tag in the component.xml to reference the class (and package) that you need.  For example - the reader extensions client is already in the LiveCycle application, so I don't want to include it in my component.  Instead I reference it using the <import-packages> tag:
          <import-packages>
                   <package version="1.0">com.adobe.livecycle.readerextensions.client</package>
                   <package version="1.0">com.adobe.livecycle.readerextensions.client.exceptions</package>
              </import-packages>
