0 Replies Latest reply on Jun 12, 2009 7:18 AM by Paul Reilly
    [svn:fx-trunk] 7782: * Fixed some particularly tricky issues with the global swc cache.
    Paul Reilly Level 1
      Revision: 7782
      Author:   preilly@adobe.com
      Date:     2009-06-12 07:18:35 -0700 (Fri, 12 Jun 2009)
      Log Message:
      • Fixed some particularly tricky issues with the global swc cache.
      tests Passed: checkintests
      Needs QA: NO, already cycloned.
      Needs DOC: NO
      Bug fixes: SDK-21460, SDK-21164
      API Change: NO
      Reviewer: Pete F., Peter D.
      Cycloner: Gaurav
      Code-level description of changes:
        compiler/src/java/flex2/tools/oem/Library.java
          Modified processInputs() to favor CompilerSwcContext sources over
          SourcePath sources when the CompilerSwcContext source is cached
          and the timestamps are the same.  This matches logic in
          CompilerAPI.findDefinition().
        compiler/src/java/flex2/compiler/Source.java
          Modified removeCompilationUnit() to only remove the type
          information for SwcScript based CompilationUnits, because these
          can't easily be recreated without recreating the Source.  Another
          alternative is to factor out the CompilationUnit creation from
          CompilerSwcContext.createSource() and modify AbcCompiler.parse1()
          to call it when the CompilationUnit is null.  This option seemed
          the easiest and should minimize object creation.
          Renamed copyMetaData() to copyCompilationUnit() and modified it to
          directly copy the dependencies before copying the dependency
          histories.  This is necessary, because SwcScript based
          CompilationUnit's get there dependencies from catalog.xml.
        compiler/src/java/flex2/compiler/CompilerSwcContext.java
          Modified getSource() to populate def2source with all of the
          SwcScript's definitions, so that they can all share one Source and
          CompilationUnit.  Otherwise, we have separate
          Source/CompilationUnit pairs for all the definitions in the player
          which are defined in files with multiple definitions, like Object,
          Array, Clipboard, etc.
          Updated updateObsoletedSources() to reflect change to SwcScript.
          Removed cachedSources variable, modified getCachedScript() to have
          a QName parameter, and modified cachedSources() to no longer cache
          the result, since getCachedScript() uses def2script directly.
        compiler/src/java/flex2/compiler/CompilerAPI.java
          Modified validateCompilationUnits() to check for instances of
          MultiName when validating dependencies.  Dependencies are
          MultiNames when they are read in from a cache file.  Also added
          call to removeVectorTypes().
          Modified logReasonAndRemoveCompilationUnit() to use the
          topLevelDefinitions when cleaning up the SwcScript cached
          CompilationUnits.
          Added removeVectorTypes() to clean up all the Vector based types
          created in the previous compilation.  These types are created on
          the fly by ReferenceValue.bindToTypeParamSlot() and they don't fit
          into the Flex Compiler design, because there isn't a Source and/or
          CompilationUnit for them.  As a result, there is no way to
          invalidate them or swap them out when things like playerglobal.swc
          or airglobal.swc is swapped in or out of the library or external
          library path.  This is what was causing the following error:
            Implicit coercion of a value of type flash.display:GraphicsStroke to an unrelated type flash.display:IGraphicsData. Line.as flex4/flex4/src/spark/primitives line 264 Flex Problem
          The reason was Line was passing a playerglobal.swc based
          Vector.<flash.display.IGraphicsData> into a function that was
          expecting an airglobal.swc based
          Vector.<flash.display.IGraphicsData>.  Both Vector and
          flash.display.IGraphicsData had been properly swapped out, but the
          airglobal.swc based Vector.<flash.display.IGraphicsData> was
          spilling over from the airframework project compilation.
        compiler/src/java/flex2/compiler/swc/SwcGroup.java
          Modified updateMaps() to reflect the SwcScript changes.
        compiler/src/java/flex2/compiler/swc/SwcScript.java
          Replaced the compilationUnits variable with compilationUnit now
          that all the SwcScript definitions share a single
          Source/CompilationUnit pair.  Updated the related accessors.
          Modified toString() to make it easier to see that SwcScript's can
          contain multiple definitions.
        compiler/src/java/flex2/compiler/swc/Swc.java
          Modified buildLibrary() to reflect the SwcScript changes.
        swfutils/src/java/flash/swf/tools/SyntaxTreeDumper.java
          Modified evaluate(Context cx, ParameterNode node) to also dump the
          init field.
        compiler/src/java/flex2/compiler/as3/binding/BindableSecondPassEvaluator.java
          Modified moveMetaDataToNewDefinition() to check that
          fromDefinition is not null before using it.  This should fix
          SDK-21164.
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-21460
          http://bugs.adobe.com/jira/browse/SDK-21164
      Modified Paths:
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/CompilerAPI.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/CompilerSwcContext.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/Source.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/binding/BindableSecondPassEva luator.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/Swc.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/SwcGroup.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/SwcScript.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/Library.java
          flex/sdk/trunk/modules/swfutils/src/java/flash/swf/tools/SyntaxTreeDumper.java
