0 Replies Latest reply on Jun 12, 2009 8:38 AM by Paul Reilly
    [svn:fx-trunk] 7785: * Fixed issue with library projects not appending to the library and
    Paul Reilly Level 1
      Revision: 7785
      Author:   preilly@adobe.com
      Date:     2009-06-12 08:38:22 -0700 (Fri, 12 Jun 2009)
      Log Message:
      • Fixed issue with library projects not appending to the library and
        external library path when configured via FlashBuilder.  Also hand
        editted all the project files to more closely match the Ant
        build.xml equivalents.  In the future, my recommendation is that
        changes to the project files be done by hand, because it's very
        difficult to make fine grained changes with FlexBuilder or
        FlashBuilder without the files being reformatted and without new
        defaults being inserted, especially when loading version 3 files
        into Flash Builder 4.
      tests Passed: checkintests
      Needs QA: YES
      Needs DOC: NO
      Bug fixes: SDK-21156
      API Change: NO
      Reviewer: Pete F.
      Cycloner: Gaurav
      Code-level description of changes:
        modules/compiler/src/java/flex2/tools/oem/internal/OEMConfiguration.java
          Modified getOptions() to handle Map based values in the "more"
          arg.
          Modified setComponentManifests() to use "more", so the library
          will be appended.
        modules/compiler/src/java/flex2/compiler/swc/SwcAPI.java
          Modified setupNamespaceComponents() to use the new
          NameMappings.isLookupOnly().
        modules/compiler/src/java/flex2/compiler/util/NameMappings.java
          Modified addLookupOnly() and isLookupOnly() to require an
          additional namespaceURI parameter and changed the lookupOnly
          variable from Set.
        modules/compiler/src/java/flex2/compiler/util/ManifestParser.java
          Modified startElement() of the Parser inner class to use the new
          NameMappings.addLookupOnly().
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-21156
      Modified Paths:
          flex/sdk/trunk/development/eclipse/flex/airframework/.actionScriptProperties
          flex/sdk/trunk/development/eclipse/flex/airframework/.flexLibProperties
          flex/sdk/trunk/development/eclipse/flex/flash-integration/.actionScriptProperties
          flex/sdk/trunk/development/eclipse/flex/flash-integration/.flexLibProperties
          flex/sdk/trunk/development/eclipse/flex/flex4/.actionScriptProperties
          flex/sdk/trunk/development/eclipse/flex/flex4/.flexLibProperties
          flex/sdk/trunk/development/eclipse/flex/flex4test/.actionScriptProperties
          flex/sdk/trunk/development/eclipse/flex/framework/.actionScriptProperties
          flex/sdk/trunk/development/eclipse/flex/framework/.flexLibProperties
          flex/sdk/trunk/development/eclipse/flex/rpc/.actionScriptProperties
          flex/sdk/trunk/development/eclipse/flex/rpc/.flexLibProperties
          flex/sdk/trunk/development/eclipse/flex/utilities/.actionScriptProperties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/SwcAPI.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/ManifestParser.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/NameMappings.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/internal/OEMConfiguration.java
