This content has been marked as final.
Show 1 reply
1. xml into list data
tbuteler Sep 17, 2008 4:07 AM (in response to Kristtee)For starters, there seems to be an error on the code you listed:
<option value="{url}">{tit}</option>
According to your XML it should be {title}. Maybe you changed something and forgot to update your XML or your HTML?
Second, to make sure we're covering everything, we need to see how you've created the dataset with Spry, with a line like this (example):
var ds1 = new Spry.Data.XMLDataSet("list.xml", "leads/lead");
Notice how the second part (XPath declaration) tell Spry where in your XML you want it to check for data. It's likely that it's looking in the wrong place if your list is not showing, but no errors are informed.
Lastly, make sure you have the external links to the Spry JS files (considering they're on the same root as your HTML and XML, otherwise correct the URLs):
<script language="JavaScript" type="text/javascript" src="xpath.js"></script>
<script language="JavaScript" type="text/javascript" src="SpryData.js"></script>
That should do it, right? It is quite simple, so you should nail it in no time.
Best regards,
Tomas
