0 Replies Latest reply on Jun 12, 2009 1:49 PM by Carol L. Frampton
    [svn:fx-trunk] 7799: - Reproduced and fixed the ENTER key issue that Gordon found a few weeks ago that neither Peter or I could reproduce at the time .
    Carol L. Frampton Level 2
      Revision: 7799
      Author:   cframpto@adobe.com
      Date:     2009-06-12 13:48:31 -0700 (Fri, 12 Jun 2009)
      Log Message:
      - Reproduced and fixed the ENTER key issue that Gordon found a few weeks ago that neither Peter or I could reproduce at the time.  I believe there is a bug in TLF that it doesn't always observe the manageEnter configuration setting.  My fix will work whether or not TLF is fixed since the ENTER key never gets to TLF.
      - Moved the keyDownHandler and the focusOutHandler from RET to RETCM so it would be symmetric with the focusInHandler already there.
      - Can't select in the numeric stepper if not editable or selectable.  The text APIs ignore the visual selectable and editable properties so the caller must check these first.
      QA Notes: test enter in multiline TextArea single line TextInput/NumericStepper components
      Doc Notes:SDK-21783
      Reviewers: Gordon
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-21783
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/components/NumericStepper.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/primitives/RichEditableText.as
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/primitives/supportClasses/RichEditable TextContainerManager.as
