0 Replies Latest reply on Jun 12, 2009 6:12 PM by Darrell Loverin
    [svn:fx-trunk] 7820: Partial fix for SDK-21711
    Darrell Loverin Level 4
      Revision: 7820
      Author:   dloverin@adobe.com
      Date:     2009-06-12 17:41:28 -0700 (Fri, 12 Jun 2009)
      Log Message:
      The fix changes Toolkit.getDepenedencyOrder() and Toolkit.getLibraryDependencies() to throw an exception if there is a circular dependency. With the exception the caller will not get bad return values caused by a circular dependency.
      Still need to remove duplicate swc script entries so avoid circular dependencies.
      QE Notes: Some tests will need to be updated to catch the exception.
      Doc Notes: none.
      Bugs: SDK-21711
      Reviewer: Pete
      tests: checkintests
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-21711
      Modified Paths:
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/SwcDependencyInfo.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/SwcDependencyInfoImpl.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/SwcDependencyUtil.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler_en.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/Toolkit.java
      Added Paths:
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/OEMException.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/OEMException_en.properties
