Anyone kindly advise what is the best way to publish captivate quiz to scorm object that can add to a Learning Management System (Moodle) to record results/scores of the quiz. Thanks
You may get an answer in the moodle forum. http://moodle.org/support/
Thank you Tony, I did go there before. I may re-visist there again.
Hi there,
One thing that you might want to look at is to increase both the post size and the file upload size in Moodle. Please note that in order to make this adjustment you will need to modify your server's php.ini. If you are not sure how to do this then please contact your Moodle Administrator.
Best - Mark
<a href="http://macrofireball.blogspot.com/"><strong>Visit the macrofireball blog</strong></a>
Hi, I am trying to figure this out also
I found this thread in the Moodle forums that may help.
Cheers,
Matt.
