2 Replies Latest reply on Sep 21, 2008 12:52 PM by jaabi
    Binding XML to ComboBox
    jaabi
      I'd appreciate any help with the following problem.
      In the method theaterSearchResultHandler(), I'm trying to assign a portion of the xml (returned from an HTTPService call) to the dataProvider property of a ComboBox. I've included both the method and the xml that's returned.
      When I dump event.result, I see the xml is there. But somehow the dataProvider property ends up with an empty object.
      Any suggestions? Thanks much.
      LT
        • 1. Re: Binding XML to ComboBox
          Level 7
          "jaabi" <webforumsuser@macromedia.com> wrote in message
          news:gb4raj$t5c$1@forums.macromedia.com...
          > Hi,
          > of
          > of a
          > LT
          > //my method where I try to assign the Cinema node of the XML object to the
          > dataProvider property of my ComboBox.
          > private function theaterSearchResultHandler(event:ResultEvent):void
          > appView.gotoMovieEventSelection();
          > saveTrackingInfo(SELECT_CINEMA);
          > appView.theaterComboBox.labelField = 'Name';
          > appView.theaterComboBox.dataProvider =
          > event.result.CinemaSearch.Response.Cinemas.Cinema;
          try
          event.result.Response.Cinemas.Cinema
          • 2. Re: Binding XML to ComboBox
            jaabi Level 1
            Thanks for the suggestion Amy.
            Turns out my problem was elsewhere: in the HTTPService tag I used to download the XML. I had set the HTTPService's resultFormat property to 'xml'. I didn't realize that Flash automatically converts xml nodes into actionscript objects without the developer having to do anything. Once I removed the resultFormat property and the combobox worked like it should, binding to the resulting array of Cinema objects.
