4 Replies Latest reply on Sep 18, 2010 3:21 AM by Tim Durham
    Is it possible to create a SD project and then replace the video later with HD?
    Tim Durham
      There are a few reason why I want to do this. One is to speed up editing in CS3 and the other is to produce both DVD and BVD discs as the final product.
      My idea was to create a SD project, complete the edit and export the SD master for the DVD. Next I wanted to off-line all the files and then batch capture the video again as HD. In an experiment I found that I needed an HD project so I copied the SD project into an HD project. However, I was not very successful -the captured HD had to be rendered and was not seen as the right format.
      Can you tell me if the idea is daft or if there is a correct way of doing this in CS3?
      Thanks, Tim
