1 Reply Latest reply on Jun 14, 2009 5:17 PM by SiHoop
    Binding to an array
    SiHoop Level 1
      My application uses a couple of classes:TextParser and MazeMaker
      The main application creates textParser1 an instance of TextParser:
      private var textParser1:TextParser
      textParser1 = new TextParser(etc.)
      TextParser contains a public array:answersArray which is Bindable
      Within textParser, I generate a series of instances of MazeMaker:
      public    var mazeLayout:MazeMaker
      mazeLayout=new MazeMaker( etc.)
      answersArray[myVal]=mazeLayout.selectedAnswer
      myVal++
      Now, within the MazeMaker class I create selectedAnswer:
      [Bindable] public var selectedAnswer:String=""
      When I select a button in MazeMaker I use the following to access some content.
      selectedAnswer=event.currentTarget.getChildAt(0).text
      My goal is that when selectedAnswer changes its value,so too the value of answersArray[myVal] should also change its value and that should show up when I access answersArray in a function in the main application:
      trace("My value="+textParser1.answersArray)
      However. It doesn't work I seem to be unable to update the value of answersArray[myVal]. What can I do to correct this?
      Thanks!
