0 Replies Latest reply on Jun 14, 2009 8:21 PM by jamieg-au
    SQLassembler does not handle NULLS in date type well
    jamieg-au
      I am having problems with SQLassembler and dates.
      When I update a entry in a table that has a Date item that is "NULL", the SQL assembler appears to ignore the #date_item# and an error occures..
      [LCDS]12:13:46.999 [DEBUG] [Service.Data.SQL] SQL Assembler jdbc exception on operation=update-item error=java.sql.SQLException: No value specified for parameter 8
      This error does not happen is the item has a valid date.
      Now, this led me to look at..
      [LCDS]12:13:47.030 [ERROR] [Message.General] Exception when invoking service 'data-service': flex.data.adapters.AdapterException: An error executing SQL caused the operation to fail. If debug level logging is enabled for the SQL Assembler, details are logged on the server.
        incomingMessage: Flex Message (flex.data.messages.DataMessageExt)
          operation = transacted
          id = null
          clientId = F8ED2FA3-2CBB-2828-A722-E1B0BD29F922
          correlationId =
          destination = sql-crm_item
          messageId = 1B3E8755-CAB2-7C8F-53BC-E1B11358DC1B
          timestamp = 1245032026968
          timeToLive = 0
          body =
            Flex Message (flex.data.messages.DataMessage)
                operation = update
                id = ASObject(11380629){keyfield=542}
                correlationId = 1B3E8755-CAB2-7C8F-53BC-E1B11358DC1B
                messageId = 17D39013-4D11-DFEF-5B30-E1B11358E3EB
                timestamp = 1245032026984
                timeToLive = 0
                body =
                    note
                  [Proxy(inst=ASObject(30886915){assign_to=jamieg, recordtype= , due_date=null, actiontype= , date_completed=null, username=jamieg, lookupkey=NetworkMonitor_08000, date_time=Fri Jun 12 18:25:41 EST 2009, keyfield=542, note=you too  34, progress_state=Not Started}) proxyClass=class flex.messaging.io.MapProxy descriptor=[ excludes: null]],
                  [Proxy(inst=ASObject(10018056){assign_to=jamieg, recordtype= , due_date=null, actiontype= , date_completed=null, username=jamieg, lookupkey=NetworkMonitor_08000, date_time=Fri Jun 12 18:25:41 EST 2009, keyfield=542, note=you too  345, progress_state=Not Started}) proxyClass=class flex.messaging.io.MapProxy descriptor=[ excludes: null]]
                hdr(DSEndpoint) = my-rtmp
                hdr(DSId) = B8004617-F61C-8D57-9861-6C965736D87D
      See the"descriptor=[ excludes: null]]" part..  Seems to indicate that, because the item is NULL, it is not available to the SQLassembler, so when it is listed on the sql-update as #date_item#, there is no item in the object to pull this from, and I end up in an error.
      This is what I think is happening...  So I looked for a way to disable descriptor=[ excludes: null]]...  No idea.
      Any clues on this would be great..
      James
