1 Reply Latest reply on Aug 6, 2008 10:07 AM by ntsiii
    Flex builder not working
    Isaac Fung Level 1
      I have been using flex builder 2 for nearly 1 year and things was going well until recently. I got the following message:
      "An out of memory error has occurred. You can prevent these errors in the future by increasing your heap size before you start the workbench using the -vmargs -Xmx command line option
      You are recommended to exit the workbench.
      Subsequent errors may happen and may terminate the workbench without warning."
      I followed the instruction of exiting the workbench and then add the following line:
      java.args=-Xms256m -Xmx512m -Dsun.io.useCanonCaches=false
      as described in livedocs.
      I restarted everything but the IDE was still unable to go back to its former performance, either terribly slow or just dead. Please help.
