3 Replies Latest reply on Oct 28, 2008 4:11 PM by Kevin Goldsmith
    Twirl Filter Export?
    Rich Tretola
      Trying to export Twirl into a pbj and I get:
      ERROR: (line 95): evaluatePixel is the only function supported in hydra byte code
      ERROR: (line 118): evaluatePixel is the only function supported in hydra byte code
      It runs within Pixel Bender but can not export. Any ideas?
        • 1. Re: Twirl Filter Export?
          Kevin Goldsmith Level 3
          That is a bug in the toolkit. The AIF_FLASH_TARGET is being ignored when exporting. For now, you can remove all the code in the #if !AIF_FLASH_TARGET block and it will export correctly. We will fix that bug in the next release of the toolkit.
          • 2. Re: Twirl Filter Export?
            omuppi1
            Kevin,
            I am running into the same problem with a kernel I wrote.. I am running the latest Pixel Bender toolkit from the labs site. Is a new version of the toolkit coming out any time soon?
            Also, I dint understand your workaround. Where do I make these changes? Can you please eloborate?
            thanks,
            Om
            • 3. Re: Twirl Filter Export?
              Yes, a new version of the toolkit is coming soon that fixes this issue.
              remove all the code between:
              // Region functions are not available in Flash targets, so we only define
              // the functions if we are executing on a different backend.
              and
              #endif
              (the changed function)
              that will allow you to export twirl as a pbj file.
