2 Replies Latest reply on Jun 15, 2009 4:23 AM by tim_mickelson
    Highlight Tree item from selectedIndex
    tim_mickelson
        Hello,
        I am using Tree.selectedIndex to select an item in a Tree object. The node is not "highlighted" though. Does anyone know how I can highlight the selected item, as if I had "clicked" with the mouse?
        Greetings Tim Mickelson
        • 1. Re: Highlight Tree item from selectedIndex
          leybniz Level 4
          use selectedItem property instead of selectedIndex
          • 2. Re: Highlight Tree item from selectedIndex
            tim_mickelson Level 1
            Thanks, I have resolved this problem. The problem was that I needed to use the function callLater because before the selectedIndex I had used an expandItem function and this function is asynch and created this problem for me.
                        var array:Array = [treeIndex.selectedIndex];
                        this.callLater(selectIndex,array);
                        private function selectHelpCallBack(e:ResultEvent):void{
                            if(e.result!=null&&e.result is String){
                                textHelp.text = e.result as String;
              Greetings, Tim
