0 Replies Latest reply on Jun 15, 2009 4:52 AM by robegv
    Bindable combobox - selected item/index
    robegv
      Hi
      I am trying to bind a datagrid item to a combox, so that when the user selects the item in the datagrid the form displays the selected data for editing, however one of my items is a combobox using a dataprovider.
      I would like the item selected in the datagrid to match the selected item in the combobox, this part is fine however if my datagrid item is null then i cannot get the combox to set the selected index to -1??
      (the same happens if you use the CRUD wizard in flex builder 3 for coldfusion)
      I am using the following code for my custom combobox;
      <mx:ComboBox
      xmlns:mx="http://www.adobe.com/2006/mxml" xmlns="*" creationComplete="componentInit()"
      <mx:Script>
      <![CDATA[
      import
      mx.utils.ObjectUtil;
      import
      mx.controls.Alert;
      Bindable
      public var valueField:String = ""
      Bindable
      public var
      labelFields:Array = [];
      public function componentInit():
      void
      this
      .labelFunction = renderLabelFunction;
      public function
      renderLabelFunction(item:Object):String
      var result:String = ""
      if
      (labelFields.length == 0)
      if (labelField != null
      return
      item[labelField];
      else
      return
      item.toString();
      else
      for(var
      i:int=0; i < labelFields.length; i++)
      if
      (i > 0)
      result +=
      result += item[labelFields[i]];
      return
      result;
      override public function set selectedItem(val:Object):
      void
      //Alert.show(valueField +":" +ObjectUtil.toString(val));
      if( this.valueField != null
      for(var i:int=0; i < this
      .dataProvider.source.length; i++)
      var item:Object = this
      .dataProvider.source[i];
      if
      ( item[valueField]== val )
      // if it matches, make it selected.
      this
      .selectedIndex = i;
      break
      else
      this
      .selectedIndex = -1;
      public function get
      selectedItemValue():Object
      if( this.valueField != null && selectedItem != null
      return
      selectedItem[valueField];
      else
      return
      text;
      </mx:Script>
      </mx:ComboBox>
      and the MXML part calling the combox is:-
      <mx:DataGrid id="clientDatagrid" selectedIndex="1" visible="true"/>
      <mx:Form height="305">
        <mx:FormItem direction="horizontal" label="Surname" required="true" visible="true" width="100%" horizontalAlign="left">
           <mx:TextInput enabled="true" id="Surname" text="{clientDatagrid.selectedItem.Surname}" width="100%" visible="true"/>
        </mx:FormItem>
        <mx:FormItem direction="horizontal" label="Forename" required="true" visible="true" width="100%" horizontalAlign="left">
           <mx:TextInput enabled="true" id="Forename" text="{clientDatagrid.selectedItem.Forename}" width="100%" visible="true"/>
        </mx:FormItem>
        <components:BindableComboBoxa id="gender"
                    dataProvider="{genderData}"
                    valueField="Code"
                    labelField="Description"
      </mx:form>
      any help would be much appreciated
      thank you
