3 Replies Latest reply on Jun 15, 2009 3:52 PM by robdillon
    Interactive slideshow with custom Quicktime control
    Retrozilla
      Hi
      I have huge amount of pics that I want to present. Therefore I decided to do it with a Quicktime Movie slideshow. Instead of using the given Quicktime Controls in the Property Inspector I rather would like my own control buttons. I tried it with the Quicktime Behaviors from the Library. The play button worked fine, but the forward and backward button did not. What might be the problem?
      Regards
      Simon
        • 1. Re: Interactive slideshow with custom Quicktime control
          robdillon Most Valuable Participant
          Can you tell us what you wanted to happen with the forward and back controls versus what actually happened?
          • 2. Re: Interactive slideshow with custom Quicktime control
            Retrozilla Level 1
            Hi Rob
            I simply would like to jump from one slide to the next in a Quicktime Movie. Clicking on the two Arrow Buttons from the Quicktime Controls does exactly this: I can jump forward to the next or jump back to the last slide.
            My problem with the Quicktime Behaviors from the Library: The Forward and Backward Scripts do something else. When I click once nothing happens, when I keep clicking the button, it reacts like a slider, but unfortunately no jump.
            Did this make it clearer?
            • 3. Re: Interactive slideshow with custom Quicktime control
              That QT button behavior won't do what you want. It does a lot different things but its not designed to move one frame forward or back. A behavior like this wil do the job. Depending on your QT movie, you may need to adjust the number of frames that are moved each time the button is used. This is the next frame behavior:
              property QTSprite
              property thisDuration
              property thisMember
              property customCursor
              property thisSprite
              on getPropertyDescriptionList
                myPropList = [:]
                myPropList.addProp(#QTSprite,[#comment:"enter the Quicktime sprite number:",#format:#integer,#default:""])
                myPropList.addProp(#customCursor,[#comment:"pick a cursor:",#format:#cursor,#default:280])
                return myPropList
              end
              on beginSprite me
                thisSprite = me.spriteNum
                thisMember =  sprite(QTSprite).member
                thisDuration = thisMember.duration
                sprite(thisSprite).cursor = customCursor
              end
              on endSprite me
                sprite(thisSprite).cursor = 0
              end
              on mouseUp me
                if sprite(QTSprite).movieTime < thisDuration then
                  sprite(QTSprite).movieTime = sprite(QTSprite).movieTime + 1
                end if
              end
              and this is the previous button behavior:
              property QTSprite
              property thisMember
              property thisSprite
                myPropList = [:]
                return myPropList
              end
              on beginSprite me
              end
              on endSprite me
              end
              on mouseUp me
                if sprite(QTSprite).movieTime > 1 then
                  sprite(QTSprite).movieTime = sprite(QTSprite).movieTime - 1
                end if
              end
              Try these and see if they work for you.
