2 Replies Latest reply on Jun 15, 2009 11:55 AM by pixlor
    control vector sub points
    kimikimish
      I want to move the right subpoint solely, but when I move it, the left subpoint move as well.
      Do you know anyhow to let the software know that I only want to move one sub point not both of them
        • 1. Re: control vector sub points
          Dave Hogue Level 2
          Make sure you are using the Subselect tool (the white arrow), not the Select tool (the black arrow.)
          (1) select the vector object (all of the points will be hollow or white)
          (2) use the sub-select tool and select the one point you want to move (it will become filled or blue)
          (3) use the seb-select tool or the arrow keys on your keyboard to move the selected point
          You can also use the sub-select tool to select multiple points (by SHIFT+click) and move all of them at the same time.
          • 2. Re: control vector sub points
            pixlor Level 4
            Use the Subselection tool, instead of the Selection tool:
            Also, Fireworks has a few additional drawing tools under Window > Other > Path.
