0 Replies Latest reply on Jun 15, 2009 6:43 AM by ~SMILING RIVERMAN~
    CFGRID rownumberer
    ~SMILING RIVERMAN~
      I am trying to take advantage of the Ext.grid.RowNumberer function in conjunction with CFGRID.
      http://extjs.com/deploy/dev/docs/?class=Ext.grid.RowNumberer
      The problem I am having is with knowing how to add the RowNumberer to the grid.
      The obvious reason I am looking to add this function is to add the row number. The less obvious one is that I don't want the row numbers to reorder when you sort by another column. In other words, when you select a row to sort by, I want the row number to still be in the order of 1,2,3,4,5,etc., not 1,4,5,3,2,etc.
      What is the best way to get the RowNumberer function to work with CFGRID (be it through JavaScript or during the build process)? I am using a bind to a CFC if this effects displaying the RowNumberer.
      Your help is appreciated.
