1 Reply Latest reply on Jun 15, 2009 7:34 AM by Michael Borbor
    Does Flex support mx.charts.renderers.DiamondItemRenderer ?
    smilydolphin
      I have one chart project in flex builder, and I tried to build it in Flex sdk using ant task. I am getting the following error.
      Error: Unable to locate specified base class 'mx.charts.renderers.DiamondItemRenderer' for component class 'MyChart_inlineComponent1'.
      I copied flexTasks.jar to the ant directory, and uses the default ant build file like:
      <target name="main">
              <mxmlc file="${APP_ROOT}/src/MyChart.mxml" keep-generated-actionscript="true">
                  <load-config filename="${FLEX_HOME}/frameworks/flex-config.xml"/>
                  <source-path path-element="${FLEX_HOME}/frameworks"/>
              </mxmlc>
          </target>
      I am wondering whether flex SDk support mx.charts.renderers.DiamondItemRenderer, and if it does, then what I need to do to make it work in Flex SDK.
      Thanks in advance.
        • 1. Re: Does Flex support mx.charts.renderers.DiamondItemRenderer ?
          Michael Borbor Level 4
          The charting components are not a part of the free Flex SDK, but a
          part of Flex Builder.
          Sincerely,
          Michael
                  <mxmlc file="$/src/MyChart.mxml" keep-generated-
                      <load-config filename="$/frameworks/flex- > config.xml"/> >             <source-path path-element="$/frameworks"/>
                  </mxmlc>
              </target>
          Thanks in advance.
