7 Replies Latest reply on Jun 25, 2009 2:22 AM by user2222
    OutOfMemoryError in the Workbench ES - Any Good Idea or Solution
    user2222 Level 1
      Hello everyone,
      I very often get some OutOfMemoryError in the Workbench ES.
      My configuration:
      Hardware: Intel Core 2 Quad - Q9550 - 2.83 Ghz - 4Go of RAM - 32 bits (this is a new workstation computer).
      Software: Windows XP pro service pack 3.
      JBoss for Adobe LiveCycle ES - Jboss Livecycle version 8.2 with SP2 of LiveCycle ES and Workbench.
      When a try to add a component in the workbench, I get an outOfMemoreException in the log file. I am developpoing a component which is a ECM Connector.
      Here is my trace:
      !SESSION 2009-06-15 15:45:38.741 -----------------------------------------------
      eclipse.buildId=unknown
      java.version=1.5.0_11
      java.vendor=Sun Microsystems Inc.
      BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=fr_CH
      Framework arguments:  #Product Runtime Configuration File -is:javaconsole
      Command-line arguments:  -os win32 -ws win32 -arch x86 #Product Runtime Configuration File -is:javaconsole
      !ENTRY com.adobe.ide.singlesignon 1 1 2009-06-15 15:45:40.444
      !MESSAGE LiveCycle Workbench ES version '8.2.1.2'
      !ENTRY com.adobe.ide.singlesignon 1 1 2009-06-15 15:46:06.461
      !MESSAGE User 'administrator' logged in to server 'Livecycle ES - localhost' (hostname: 'localhost')
      !ENTRY org.eclipse.osgi 2 1 2009-06-15 15:46:09.226
      !MESSAGE NLS unused message: ValidationTable_Validate in: I18N
      !ENTRY org.eclipse.ui 4 4 2009-06-15 15:46:09.836
      !MESSAGE Invalid Menu Extension (Path is invalid): org.eclipse.ui.edit.text.gotoLastEditPosition
      !ENTRY com.adobe.DSC_Admin_UI 4 4 2009-06-15 15:54:28.661
      !MESSAGE failed to retrieve list of components
      !STACK 0
      ALC-DSC-000-000: com.adobe.idp.dsc.DSCRuntimeException: Internal error.
          at com.adobe.idp.dsc.provider.impl.soap.axis.sdk.SoapAxisDispatcher.throwExceptionHandler(So apAxisDispatcher.java:207)
          at com.adobe.idp.dsc.provider.impl.soap.axis.sdk.SoapAxisDispatcher.doSend(SoapAxisDispatche r.java:125)
          at com.adobe.idp.dsc.provider.impl.base.AbstractMessageDispatcher.send(AbstractMessageDispat cher.java:57)
          at com.adobe.idp.dsc.clientsdk.ServiceClient.invoke(ServiceClient.java:208)
          at com.adobe.idp.dsc.registry.component.client.ComponentRegistryClient.invoke(ComponentRegis tryClient.java:373)
          at com.adobe.idp.dsc.registry.component.client.ComponentRegistryClient.getComponents(Compone ntRegistryClient.java:63)
          at com.adobe.dsc.contentprovider.MixedRegistryContentProvider$RegistryRootEntry.getChildren( MixedRegistryContentProvider.java:150)
          at com.adobe.dsc.contentprovider.MixedRegistryContentProvider.getChildren(MixedRegistryConte ntProvider.java:575)
          at org.eclipse.jface.viewers.AbstractTreeViewer.getRawChildren(AbstractTreeViewer.java:1166)
          at org.eclipse.jface.viewers.TreeViewer.getRawChildren(TreeViewer.java:768)
          at org.eclipse.jface.viewers.AbstractTreeViewer.getFilteredChildren(AbstractTreeViewer.java: 574)
          at org.eclipse.jface.viewers.AbstractTreeViewer.getSortedChildren(AbstractTreeViewer.java:54 3)
          at org.eclipse.jface.viewers.AbstractTreeViewer$1.run(AbstractTreeViewer.java:728)
          at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:67)
          at org.eclipse.jface.viewers.AbstractTreeViewer.createChildren(AbstractTreeViewer.java:705)
          at org.eclipse.jface.viewers.TreeViewer.createChildren(TreeViewer.java:892)
          at org.eclipse.jface.viewers.AbstractTreeViewer.handleTreeExpand(AbstractTreeViewer.java:125 1)
          at org.eclipse.jface.viewers.AbstractTreeViewer$4.treeExpanded(AbstractTreeViewer.java:1263)
          at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:181)
          at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:66)
          at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:928)
          at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:952)
          at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:937)
          at org.eclipse.swt.widgets.Tree.wmNotifyChild(Tree.java:6343)
          at org.eclipse.swt.widgets.Control.WM_NOTIFY(Control.java:3794)
          at org.eclipse.swt.widgets.Composite.WM_NOTIFY(Composite.java:1166)
          at org.eclipse.swt.widgets.Control.windowProc(Control.java:3298)
          at org.eclipse.swt.widgets.Display.windowProc(Display.java:4025)
          at org.eclipse.swt.internal.win32.OS.CallWindowProcW(Native Method)
          at org.eclipse.swt.internal.win32.OS.CallWindowProc(OS.java:1851)
          at org.eclipse.swt.widgets.Tree.callWindowProc(Tree.java:1321)
          at org.eclipse.swt.widgets.Tree.WM_LBUTTONDOWN(Tree.java:5203)
          at org.eclipse.swt.widgets.Control.windowProc(Control.java:3279)
          at org.eclipse.swt.widgets.Tree.windowProc(Tree.java:4783)
          at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
          at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:1932)
          at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:2966)
          at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:1930)
          at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1894)
          at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:422)
          at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
          at com.adobe.lcide.rcp.Application.run(Unknown Source)
          at org.eclipse.core.internal.runtime.PlatformActivator$1.run(PlatformActivator.java:78)
          at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLau ncher.java:92)
          at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.jav a:68)
          at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:400)
          at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:177)
          at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
          at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
          at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
          at java.lang.reflect.Method.invoke(Unknown Source)
          at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336)
          at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
          at org.eclipse.core.launcher.Main.run(Main.java:977)
          at org.eclipse.core.launcher.Main.main(Main.java:952)
      Caused by: java.lang.OutOfMemoryError: Java heap space; nested exception is:
          at org.apache.axis.message.SOAPFaultBuilder.createFault(SOAPFaultBuilder.java:221)
          at org.apache.axis.message.SOAPFaultBuilder.endElement(SOAPFaultBuilder.java:128)
          at org.apache.axis.encoding.DeserializationContext.endElement(DeserializationContext.java:10 87)
          at org.apache.xerces.parsers.AbstractSAXParser.endElement(Unknown Source)
          at org.apache.xerces.impl.XMLNSDocumentScannerImpl.scanEndElement(Unknown Source)
          at org.apache.xerces.impl.XMLDocumentFragmentScannerImpl$FragmentContentDispatcher.dispatch( Unknown Source)
          at org.apache.xerces.impl.XMLDocumentFragmentScannerImpl.scanDocument(Unknown Source)
          at org.apache.xerces.parsers.XML11Configuration.parse(Unknown Source)
          at org.apache.xerces.parsers.XMLParser.parse(Unknown Source)
          at org.apache.xerces.parsers.AbstractSAXParser.parse(Unknown Source)
          at org.apache.xerces.jaxp.SAXParserImpl$JAXPSAXParser.parse(Unknown Source)
          at javax.xml.parsers.SAXParser.parse(Unknown Source)
          at org.apache.axis.encoding.DeserializationContext.parse(DeserializationContext.java:227)
          at org.apache.axis.SOAPPart.getAsSOAPEnvelope(SOAPPart.java:696)
          at org.apache.axis.Message.getSOAPEnvelope(Message.java:424)
          at org.apache.axis.handlers.soap.MustUnderstandChecker.invoke(MustUnderstandChecker.java:62)
          at org.apache.axis.client.AxisClient.invoke(AxisClient.java:206)
          at org.apache.axis.client.Call.invokeEngine(Call.java:2765)
          at org.apache.axis.client.Call.invoke(Call.java:2748)
          at org.apache.axis.client.Call.invoke(Call.java:2424)
          at org.apache.axis.client.Call.invoke(Call.java:2347)
          at org.apache.axis.client.Call.invoke(Call.java:1804)
          at com.adobe.idp.dsc.provider.impl.soap.axis.sdk.SoapAxisDispatcher.doSend(SoapAxisDispatche r.java:123)
          ... 54 more
      Thank you very much.
      A continue my message in the next POST.
      Thank you very much for all who will have a great idea.
      I meet these errors everyday.
      ECI
