3 Replies Latest reply on Jun 15, 2009 11:34 AM by Benji2008
    ArrayCollection
    lmcrun19 Level 1
      I have an ArrayCollection playing mp3's from a mx:ComboBox. I am setting labels for each mp3 in my array. In mx:combobox  I set the labelfield to display the lable, but when I run the application and select a mp3 file I get an actionscript error. I believe its because I set the labelfield for the label but I did not set anything for the "File: "index7ex.mp3" itself. Basically, in my ComboBox what else do I input in order to select the file also. Also, if anyone sees anything else wrong with what I have , I thank you in advance if you could just let me know. Thanks.
      private var dp:ArrayCollection = new ArrayCollection([{ label: "My cool song", File: "index7ex.mp3"}, { label: "Another cool song", File: "index8ex.mp3"}  ])
      <mx:ComboBox creationComplete="cb.dataProvider=dp" id="cb" change="loadSound()" width="100%" labelField="label"/>
        • 1. Re: ArrayCollection
          Benji2008 Level 1
          Maybe it wouldnt be a bad idea if you that Array Bindable,
          as for selecting the right value, I guess it depends what you do in your loadSound function,
          you must select the selectedItem-- ( cb.selectedItem.File ) - that way you can select the mp3 you want
          <mx:Script>
              <![CDATA[
                  import mx.controls.Alert;
                  import mx.collections.ArrayCollection;
                  [Bindable]
                  private function loadSound():void
                      Alert.show(cb.selectedItem.File);
          </mx:Script>
          <mx:ComboBox dataProvider="{dp}" id="cb" change="loadSound()" width="100%" labelField="label"/>
          hope this helps
          • 2. Re: ArrayCollection
            lmcrun19 Level 1
            That did the trick. Thanks.
            • 3. Re: ArrayCollection
              Benji2008 Level 1
              you're welcome
