0 Replies Latest reply on Jun 15, 2009 1:21 PM by Graphic Graeme
    Hiding XML content in Flash
    Graphic Graeme
      Ok so I have created this button that expands within a movie clip called "movie1_mc". At frame 12 the button stops expanding and an external XML file loads in 7 subnavigation buttons within a single mc called "button". After the user rolls Off the subnavigation btns the "movie1_mc" button collapses but the laoded xml content is still there. I need to get rid of the XMl content after frame 13 how can I accomplish this?
      Below is my coe that loads the XML content:
      stop();
      function loadXML(loadedX) {
          if (loadedX) {
              xmlNode = this.firstChild;
              image = [];
              total = xmlNode.childNodes.length;
          for (i=0; i<total; i++) {
              image[i] = xmlNode.childNodes[i].childNodes[0].firstChild.nodeValue;
              load_pic();
          } else {
              content = "file not loaded!";
      xmlData = new XML();
      xmlData.ignoreWhite = true;
      xmlData.onLoad = loadXML;
      xmlData.load("images.xml");
      function load_pic(){
          k = Math.floor(Math.random()*total);
          picture_1.holder.loadMovie(image[k], 1);
      //Store Button Position
      var yPosition:Number = 210;
      var xPosition:Number = 110;
      //Declare New XML Object
      var myXML:XML = new XML();
      //Set Flash to ignore the XML file's white space
      myXML.ignoreWhite = true;
      //Declare new Array to store the links from the XML file
      var links:Array = new Array();
      //Declare new Array to store the names from the XML file
      var names:Array = new Array();
      //Set XML onLoad function
      myXML.onLoad = function(){
          //Set varible to store the XML childNodes
          //This allows you to get the number of buttons in the XML file.
          //You'll use this tell flash how many times to loop the for loop.
          var linkname:Array = this.firstChild.childNodes;
          //Set a for loop
          for(i=0;i<linkname.length;i++){
              //Push the button name into the names Array
              names.push(linkname[i].attributes.NAME);
              //Push the button link into the links Array
              links.push(linkname[i].attributes.LINK);
              //Attach the button Movie Clip from the libray give it an instance name and place it on the next highest level
              _root.attachMovie("button","btn"+i,_root.getNextHighestDepth());
              //Set the y position of the buttons
              _root["btn"+i]._x = xPosition;
              //Increace the varible yPosition 15 pixel each time the loop runs to place each button under each other
              xPosition = xPosition+0
              _root["btn"+i]._y = yPosition;
              yPosition = yPosition+30;
              //Place the button name from names Array into the blackTxt text box
              _root["btn"+(i)].blackTxt.Txt.text = (names[i]);
              //Place the button name from names Array into the whiteTxt text box
              _root["btn"+(i)].whiteTxt.Txt.text = (names[i]);
              //Assign the btnOver function to the button onRollOver state.
              _root["btn"+(i)].onRollOver = btnOver;
              //Assign the btnOut function to the button onRollOut state.
              _root["btn"+(i)].onRollOut = btnOut;
              //Assign the btnRelease function to the button onRelease state.
              _root["btn"+(i)].onRelease = btnRelease;
      //Load the XML file
      myXML.load("links.xml");
      //Button Over function
      function btnOver(){
          //This referse to the current button the mouse is over
          //Go To And Stop frame 2 of the current button the mouse is over
          this.gotoAndStop(2);
      //Button Out function
      function btnOut(){
          //Go To And Stop frame 3 of the current button the mouse rolls out from
          this.gotoAndStop(3);
      //Button Release function
      function btnRelease(){
          //Set a varible named currentBtn equal to the instance name of the current button the mouse clicked on
          var currentBtn:String = this._name;
          //Set a varible named currentIndex equal to the varible currentBtn and the characters between 3rd letter and 5th of that string.
          //This will return a number between 0 and the total number of buttons
          var currentIndex:String = currentBtn.substring(3,5);
          //Get the URL from the links Array
          //Use the currentIndex varible as the index number
          getURL(links[currentIndex]);
      Any help with this is greatly appreciated
      Cheers-
      Graphic Graeme
