4 Replies Latest reply on Jun 15, 2009 6:39 PM by jaijaz
    Spark VideoPlayer problem
    jaijaz
      I am trying to work with a Spark VideoPlayer and load video into it depending on what is selected in a tree.
      I can populate a label or text field but when I try to set the source of the player is throws up this error:
      TypeError: Error #1006: value is not a function.
      at SerkoTutorials/poplulateViewer()[/Users/jai/Documents/Adobe Flash Builder Beta/SerkoTutorials/src/SerkoTutorials.mxml:22]
      at SerkoTutorials/__moduleTree_change()[/Users/jai/Documents/Adobe Flash Builder Beta/SerkoTutorials/src/SerkoTutorials.mxml:37]
      at flash.events::EventDispatcher/dispatchEventFunction()
      at flash.events::EventDispatcher/dispatchEvent()
      at mx.core::UIComponent/dispatchEvent()[E:\dev\beta1\frameworks\projects\framework\src\mx\co re\UIComponent.as:11260]
      at mx.controls.listClasses::ListBase/mouseUpHandler()[E:\dev\beta1\frameworks\projects\frame work\src\mx\controls\listClasses\ListBase.as:10153]
      at mx.controls::List/mouseUpHandler()[E:\dev\beta1\frameworks\projects\framework\src\mx\cont rols\List.as:2440]
      at mx.controls::Tree/mouseUpHandler()[E:\dev\beta1\frameworks\projects\framework\src\mx\cont rols\Tree.as:3147]
      My code is:
      <s:Application xmlns:fx="http://ns.adobe.com/mxml/2009" xmlns:s="library://ns.adobe.com/flex/spark"
      xmlns:mx="library://ns.adobe.com/flex/halo"
      minWidth="960" minHeight="675" width="100%" height="100%" creationComplete="srv.send()" xmlns:local="*">
      <s:layout>
      <s:BasicLayout/>
      </s:layout>
      <fx:Declarations>
      <mx:HTTPService id="srv" url="assets/data.xml" resultFormat="e4x"/>
      <mx:XMLListCollection id="datalist" source="{srv.lastResult.category}"/>
      </fx:Declarations>
      <fx:Script>
      <![CDATA[
      import flash.net.navigateToURL;
      private var source:String;
      private function poplulateViewer(event:Event):void{
      if (player.playing) {
      player.stop();
      var selectedNode:Object=event.target.selectedItem;
      playerPanel.title = selectedNode.@name;
      player.source(selectedNode.@file);
      private function goToJaijaz() : void
                      navigateToURL( new URLRequest( "http:www.jaijaz.co.nz" ), '_blank' );
      </fx:Script>
      <fx:Style source="SerkoTutorials.css"/>
      <s:HGroup height="50" left="10" right="10" top="10">
      <mx:Image source="assets/logo.gif"/>
      </s:HGroup>
      <s:HGroup top="60" left="10" right="10" bottom="60">
      <s:Panel id="treePanel" width="30%" height="100%" skinClass="skins.TreePanelSkin">
      <mx:Tree width="100%" height="100%" dataProvider="{datalist}" labelField="@name" change="poplulateViewer(event)"  id="moduleTree" color="#000000" borderStyle="none"/>
      </s:Panel>
      <s:Panel id="playerPanel" width="100%" height="100%" skinClass="skins.PlayerPanelSkin">
      <s:VideoPlayer id="player" width="776" height="582" skinClass="skins.CustomVideoPlayerSkin" />
      </s:Panel>
      </s:HGroup>
      <s:HGroup height="40" bottom="10" left="10" right="10">
      </s:HGroup>
      </s:Application>
      Any help would be hugely appreciated.
      Thanks.
        • 1. Re: Spark VideoPlayer problem
          Peter deHaan Level 4
          jaijaz,
          Out of curiosity, what does your "assets/data.xml" file look like?
          Peter
          • 2. Re: Spark VideoPlayer problem
            jaijaz Level 1
            <modules>
            <category name="Introduction" catid="1">
            <module name="Login and Navigation" file="assets/modules/Sample1-Amy.mp4"/>
            <module name="Manage My Profile" file="assets/modules/Sample2-Sarah.mp4"/>
            </category>
            <category name="Create Travel Bookings" catid="2">
            <module name="Commence a Quick Booking" file="assets/modules/edit.mp4"/>
            <module name="Select Air Requirements" file="this is cat2 module2"/>
            <module name="Book Air Sectors" file="this is cat2 module3"/>
            <module name="Book Rental Car" file="assets/modules/edit.mp4"/>
            <module name="Book Hotel" file="this is cat2 module2"/>
            <module name="Finalise Booking" file="this is cat2 module3"/>
            </category>
            <category name="Maintain Travel Bookings" catid="3">
            <module name="View Existing Bookings" file="this is cat3 module1"/>
            <module name="Create Booking Documentation" file="this is cat3 module2"/>
            <module name="Modify/Cancel a Booking" file="this is cat3 module3"/>
            <module name="Authorise a Booking" file="this is cat3 module2"/>
            </category>
            <category name="Administration" catid="3">
            <module name="Create a Custom Booking" file="this is cat3 module1"/>
            <module name="Manage Unused Tickets" file="this is cat3 module1"/>
            </category>
            <category name="Other" catid="3">
            <module name="Clue Card" file="this is cat3 module1"/>
            </category>
            </modules>
            • 3. Re: Spark VideoPlayer problem
              Try changing your code to this:
              player.source = selectedNode.@file.toString();
              I believe you were trying to do something like player.source(selectedNode.@file);
              Peter
              • 4. Re: Spark VideoPlayer problem
                jaijaz Level 1
                Peter, thank you so much!
                I didn't think of putting to string as I hadn't needed to do it in Flex 3 with video object there.
                Thanks heaps.
