4 Replies Latest reply on Sep 19, 2008 10:27 AM by Newsgroup_User
    performance issue for Repeater
    flyingworm
      I have a Repeater which has a dynamic number of DataGrids. The dataprovider is a XMLListCollection. When users try to refresh the page, I re-populate the XMLListCollection data and refresh the Repeater. I found that even the data keeps the same every time, the refresh will become slower and slower, like there is something in the memory need to be cleaned. I tried to clean the dataprovider every time, but it's the same. Any suggestions? Thanks.
        • 1. Re: performance issue for Repeater
          Level 7
          "flyingworm" <webforumsuser@macromedia.com> wrote in message
          news:gamjnv$fg2$1@forums.macromedia.com...
          >is
          > data
          Make sure that you're recycling the children of the repeater. Also, don't
          bind the dataProvider. Instead, just set it from Actionscript.
          HTH;
          Amy
          • 2. Re: performance issue for Repeater
            ntsiii Level 3
            When you say, "refresh the page", exactly what do you mean?
            How many items in the dataProvider?
            Have you tried setting recycleChildren="true"?
            When you say "clean the dataProvider", do you mean re-assign some variable to the repeater's dataProvider Property?
            Used incorrectly, repeater can have performance issues, but I have never see the progressive behavior you describe.
            Tracy
            • 3. Re: performance issue for Repeater
              flyingworm Level 1
              Thanks, Amy and Tracy.
              It's a little better after I used recycle children and removed dataProvider binding.
              The number of items (dataGrids) is dynamic. It could be 70. Each datagrid has 3 to 20 rows. It takes about 10 seconds to refresh the page.
              yes, "clean the dataProvider", I mean re-assign some variable to the repeater's dataProvider Property.
              • 4. Re: performance issue for Repeater
                Level 7
                news:gb0ib2$n11$1@forums.macromedia.com...
                > dataProvider
                > binding.
                > has
                Are you using custom itemRenderers in the datagrids? Depending on what they
                are, they could be part of the problem as well.
                HTH;
                Amy
