2 Replies Latest reply on May 29, 2011 8:02 AM by Justin.Buser
    Security SandBox violation error#2070 caller stage owned by
    Vamshi_Challa
      I am new to Flex3 so that i don't know much about this.I am facing  one problem of Security SandBox error#2070:caller file cannot access stage owned by.Actually i am developing a desktop application with Flex3,AIR, which downloads the swf files,xml files from the server and stores(using"app-storage:/")  in application storage.When the user clicks tree menu items in application the related files will be loaded .But the swfs are not loading propery Security sandbox error was coming when clicking to load swfs.
      I tried
      1.Security.allowDomain("*"),
      2.Security.loadPolicyFile(http://172.24.252.59/crossdomain.xml);
      3.placed crossdomain.xml file in the server.
      4.I createdone cfg file contains c:\Documents and Settings
      at the location of Application Data/Macromedia/Flash Player/#Security/FlashPlayerTrust/ Its working fine when i run the application,but after creating and installing the AIR installer getting same problem.
      Please help me.
      Here is code using for loading swf
      public class ExternalSwfLoader extends UIComponent {
      private var loader : Loader;
      private var visibleAfterLoaded : Boolean;
      private var progressHandle : Function;
      private var loadSwfComplete : Boolean = false;
      public function ExternalSwfLoader(progressHandle:Function = null, visibleAfterLoaded:Boolean = true) {
      super();
      init(progressHandle, visibleAfterLoaded);
      protected function init(progressHandle:Function = null, visibleAfterLoaded:Boolean = true) : void {
      this.visibleAfterLoaded = visibleAfterLoaded;
      this.progressHandle = progressHandle;
      //unLoad();
      public function get content() : DisplayObject {
      if (loadSwfComplete) {
      return loader.content;
      return null;
      public function loadSwf(externalSwfUrl:String, progressHandle:Function = null, visibleAfterLoaded:Boolean = true) : void {
      var request:URLRequest = new URLRequest(externalSwfUrl);
      var ldrContext:LoaderContext = new LoaderContext(false, ApplicationDomain.currentDomain);
      loader = new Loader();
      addListeners(loader.contentLoaderInfo);
      loader.load(request,ldrContext);
      if (visibleAfterLoaded) {
      addChild(loader);
      Please help me on solving this error.
      Thanks in advance.
      Vamshi.
        • 1. Re: Security SandBox violation error#2070 caller stage owned by
          Vamshi_Challa Level 1
          Hi ,
          Hear is the solution for Security error #2070.
          hope use full to any one.
          private
          function getSWF():
          void
          var urlreq:URLRequest = new URLRequest("http://localhost/Instructions.swf"
          var urlloader:URLLoader = new
          URLLoader();
          loaderContext.allowLoadBytesCodeExecution =
          true
          urlloader.dataFormat = URLLoaderDataFormat.BINARY;
          urlloader.addEventListener(Event.COMPLETE, gotSWF);
          urlloader.load(urlreq);
          //loader.loadBytes(urlreq);
          private
          function gotSWF(evt:Event):
          void
          var urlloader:URLLoader = evt.target as
          URLLoader;
          mc = evt.currentTarget
          as
          Sprite;
          if
          ( urlloader )
          urlloader.removeEventListener(Event.COMPLETE, gotSWF);
          trace("injecting swf"
          try
          loader.contentLoaderInfo.addEventListener(IOErrorEvent.IO_ERROR, errInject);
          loader.loadBytes(urlloader.data
          as
          ByteArray,loaderContext);
          catch
          (err:Error)
          Alert.show(
          "Error injecting code: "
          + err);
          else
          trace("bad urlloader"
          private
          function
          errInject(evt:Event):voidop
          Alert.show(
          + evt);
          by
          vamshi.
          • 2. Re: Security SandBox violation error#2070 caller stage owned by
            Justin.Buser Level 1
            Nope, it's not useful because it has nothing to do with the stage ownership problem that's causing the error.
