1 2 3 Previous Next 110 Replies Latest reply on Mar 18, 2017 6:24 PM by serkanu7443760
    Best Quality Exporting From HDV to DVD
    DNA Imagery
      I've searched on the web & gotten a few answers, but nothing seems to solve the situation.
      What I've tried.
      1920x1080p MPEG2, Quality 5, Min, Target, Max All Set To 60.  Came out looking like crap when it was put on a dvd.  Noisy, over contrasted (could be the tv), over colored (could be the tv).
      720x480 MPEG2-DVD, Quality 5, Min, Target, Max All Set To 9.  Came out looking worse then my previous attempt.
      Anyone have a secret formula for HDV to DVD conversion?
        • 1. Re: Best Quality Exporting From HDV to DVD
          Dan Isaacs Level 2
          I have lots of ideas for HDV -> DVD conversions and I am surprised that you have been unable to locate any of my workflows on the Premiere forums.
          I can try to help you, but I need to know a few things first:
          1. What is the exact format that you footage was shot in? I am assuming it was 1440c1080 @ 30p. Is this correct?
          2. Do your sequence settings match that of your footage (dimensions, framerate, field options, etc)
          3. You mention that you tried to output 1920x1080/30p for DVD. Does this mean that you ouput this as an "intermediary" and let Encore transcode it automatically?
          • 2. Re: Best Quality Exporting From HDV to DVD
            DNA Imagery Level 1
            I apologize as I've searched google & not these forums (although that seems intelligent now, hah).
            1. 1440x1080 60i original footage, should I be shooting in 30p for DVD conversion?
            2. Yes.
            3. I tried to output to 1920x1080/30p thinking it would give optimal quality, but I was clearly wrong.  I exported straight from Premiere to Encore to be transcoded.
            I am a bit new to doing the DVD thing b/c I do web episodes, so I just upload to web 99% of the time and it looks great, but this DVD conversion is just coming out terrible.  Any help would be appreciated.
            Thanks!
            • 3. Re: Best Quality Exporting From HDV to DVD
              Dan Isaacs Level 2
              Try this:
              On the Premiere CS4 end of things:
              1. Download these Adobe Media Encoder CS4 presets for 100Mbps MPEG-2 I-frame 4:2:2
              2. Export your 1440x1080 60i timeline using the corresponding preset from the ones above; this will create a (very large) .m2v file and .wav file
              Now some freeware tools to get the conversion done properly:
              1. Download and install the Lagarith lossless codec
              2. Download and install VirtualDub
              3. Download and install AviSynth
              4. Download and install my hd2sd() conversion package for AviSynth (instructions for installation are in the .zip file)
              Create a new blank text document in notepad, like such, and save this file as premiere.avs, and save it to the same folder as your .m2v and .wav file (edit the video and audio parameters to match your filenames). This is your "script" file for AviSynth:
              video = "myfile.m2v"
              audio = "myfile.wav"
              FFMpegSource(video)
              (audio == "") ? last : AudioDub(WavSource(audio))
              hd2sd(OutputColorSpace="YUY2", OutputBFF=true)
              1. Run VirtualDub
              2. Open your premiere.avs file in VirtualDub
              3. In VirtualDub, go to Video : Compression and select the Lagarith lossless codec
              4. Also set VirtualDub to use Video : Fast recompress mode
              5. Save your output to lagarith.avi
              6. Import lagarith.avi into Encore for transcoding and authoring
              • 4. Re: Best Quality Exporting From HDV to DVD
                Takyc
                I'm skeptical about this process. The rule of thumb is to reduce the number of transcoding as much as possible because of the quality loss in generation. I know one of the steps is outputing to a lossless codec, but generating to a first huge MPEG-2 file, then to a lagarith AVI then to another MPEG-2 seems redundant. How about just exporting to lagarith to begin with then have it transcode in Encore?
                I haven't tried your method so I really can't comment the final outcome. Just curious. I myself just export to MPEG-2 compliant files using Procoder. Load to Encore to export to DVD. There isn't any transcoding process in Encore. The DVD looks beautiful even in low bit-rate.
                • 5. Re: Best Quality Exporting From HDV to DVD
                  Dan Isaacs Level 2
                  Sure. That is a good rule of thumb. But 100Mbps MPEG-2 I-frame is damn near-lossless for HDV or AVCHD sources and export via AME is extremely fast. Furthermore, the file can be read and decompressed very efficiently – and, in the case of my workflow, it can be multithreaded nicely.
                  How about just exporting to lagarith to begin with…
                  Well, you can certainly output to an HD Lagarith AVI. That is an option. However, I have heard that Premiere CS4 can have occasional issues when exporting Lagarith. In any case, depending on content, the Lagarith file can be very large… even greater than the 100Mbps of the MPEG-2 file. The inspiration for using 4:2:2 MPEG2 I-frame came from Matrox's products; who offer an AVI codec that does essentially the same thing (presumably for simlar reasons).
                  … then have it transcode in Encore?
                  Well, a more important rule of thumb is that you must use a good scaling algorithm and high-quality deinterlacing (for 1080i) I/O … neither of which are present in any of Adobe's product line. Add to this the fact that my process allows many other options that blow the Adobe workflow out of the water in both quality and performance.
                  I have not used ProCoder in a long time. It seems to have a very good MPEG-2 encoder. However, it coists $500 – which is exactly $500 more than my method costs. ProCoder also does not have nearly as sophisticated options for scaling, deinterlacing and noise reduction.
                  Keep in mind, however, that ProCoder can read .avs script files directly. So, conceivably, you could:
                  1. Output a Lagarith HD file from Premiere (using the same dimensions / settings as your sequence)
                  2. Create your .avs script for my hd2sd() process
                  3. Open the script in ProCoder and transcode to MPEG2 for DVD
                  • 6. Re: Best Quality Exporting From HDV to DVD
                    Takyc Level 1
                    Dan, thanks for sharing that knowledage. I wasn't trying to challenge you. I like to learn more too.
                    Taky
                    • 7. Re: Best Quality Exporting From HDV to DVD
                      Dan Isaacs Level 2
                      No worries. I inferred no such "challenge" from you. You asked some good questions and I provided the clearest answers I could.
                      Actually, I have been properly challenged on this many, many times (see the similar thread on the CS3 forum!!!). I can't really take much credit for the process – I'd give most of this to the AviSynth authors and those who have created so many incredible, free plugins for it. My goal is avail these tools to a wider audience… and to help users circumvent some of the weaknesses of Premiere. I love Premiere as an editing program, but handling of different standards and conversion between them have never been the program's strong suit.
                      I also try to find the combination of existing freeware tools that provide the fastest, most efficient and reliable workflow on all computers. This can be quite challenging at times, and so I update my package(s) and process(es) fairly frequently. Many of the improvements I have made to the HD->SD process are directly attributable to other users on these forums who have taken the time to help me test this stuff out.
                      The real bummer here is that DebugMode FrameServer will not work in CS4. That was an incredibly cool workflow. This part of the process was replaced by the MPEG2 I-frame intermediary. Although it is unfortunate that such an intermediary (and slightly-less-than-lossless, at that) is required, it probably speeds-up the process in most cases. Again, exporting CBR 4:2:2 MPEG2 I-frame from AME is crazy fast on a nice computer. And, if you are using AviSynth MT 2.5.7 (multithreaded version), you can get incredible processing speeds on 4- or 8-core machines.
                      Try it out: If you run into issues I am (almost) always willing to help you resolve them so that I can continue improving my process and the advice I give others.
                      -- Dan
                      • 8. Re: Best Quality Exporting From HDV to DVD
                        Takyc Level 1
                        I'm pretty happy with the Procoder output in my current workflow. Many times I show my DVD to clients they thought those are bluray disc output. yeah it's pricey but it worth it.
                        • 9. Re: Best Quality Exporting From HDV to DVD
                          spreeni Level 1
                          @Dan Isaacs
                          I tried your HD2SD workflow via MPEG I-Frame and it works pretty well, although I'm not shure if the result is really better than using AME with MRQ setting and *important* switching to TFF. However, the avisynth file is interpreted as 1:1 pixelratio by virtualdub, procoder, and AME. I tried to force it to 16x9 by setting parameter "OutputWidescreen=true" but this makes no difference. The only way to set clip to correct AR is to force ratio in premiere or encore manually. Unfortunately this is not possible if you want to convert in AME directly. Is there a way to set AR in the script in a way, other programs handle it correctly?
                          I've found an AVS Importer plugin for CS4 wich makes converting much easier. You can load the avs-file directly into premiere, encore, AME, or AFX and do not need to recode it to a lagarith-avi first. This speeds up a lot. If you like, check http://valion.net/csavs
                          This one seems to work better than the already known PremiereAVSPlugin 1.95.
                          • 10. Re: Best Quality Exporting From HDV to DVD
                            jatmraz Level 1
                            Hello,
                            Couple of questions on the below:
                            1) Does this work for converting .MTS files?
                            2) If so, I download the Encoder presets, but where do I place them? (I didn't see any .epr files in the root of /encoder
                            FFMpegSource(video)
                            1. Run VirtualDub
                            • 11. Re: Best Quality Exporting From HDV to DVD
                              spreeni Level 1
                              In export settings choose mpeg2-format, then click on the second icon right from the field 'presets' with witch you can load your favorite preset of Chris' archive. From now on this one will always be listed in the presets-list of mpeg2 format.
                              And yes, you can convert every stuff PPro is able to handle.
                              • 12. Re: Best Quality Exporting From HDV to DVD
                                Dan Isaacs Level 2
                                Oh, yes… it is… and faster.
                                Does that make any in difference in quality? It shouldn't.
                                Correct. One of the silly things about standalone AME is that you cannot override any of its assumptions, like PAR or field order.
                                I don't really think so. Encoding 2-pass from a static AVI file will be faster than re-processing the script for each pass. Furthermore, if you use the multithreaded version of AviSynth like I do, you can get very excellent speed writing from VirtualDub. I am pretty sure that the PPro Import plugin does not multithread nicely.
                                If you want to try this, download AviSynth 2.5.7 MT … replace the avisynth.dll in your System32 folder (os SysWow64 on 64-bit OSes) and copy mt.dll to your AviSynth plugins folder. Now, add this as the first line of your script to:
                                SetMTMode(2)
                                Save the Lagarith .AVI file from VirtualDub. It should be a lot faster now if you have 2 or more cores/processors.
                                • 13. Re: Best Quality Exporting From HDV to DVD
                                  Dan Isaacs Level 2
                                  Not really. However, you can use AME to convert your .MTS files to MPEG2 I-frame and process the resulting files, but this is almost a bit silly.The best way to handle individual .MTS files in AviSynth is to use DGIndex but the process is a little more complicated.
                                  What are you trying to do and why? I can probably help you better if I know your intentions.
                                  • 14. Re: Best Quality Exporting From HDV to DVD
                                    mickkeay Level 1
                                    Hi Takyc
                                    I have used Dans method with great results. I also have procoder (but not for this) and have always liked it.
                                    I want to give Procoder it a try with this and compare. What output settings are you using  from AME (to then feed into procoder)  I am assuming your source is interlaced - 1080i - because that is where the all adobe workflow badly falls down.   My sequence is 1440 x 1080i  - 50 I am in PAL land - Thanks Mike
                                    • 15. Re: Best Quality Exporting From HDV to DVD
                                      Takyc Level 1
                                      Mike,
                                      I am using Matrox RTX2 card so I have an immediate codec to use. I export to Matrox HD AVI i 1080por 1080i depends on which project. then load the AVI to Procoder to export to different bit-rates for DVD, BD authoring.
                                      30p is not a dvd or bd standard. but Procoder will nicely transcode that 30p video to 60i mpeg or h.264 for authoring.
                                      I also make use of Procoder Watch Folder feature to encode the video on a separate computers. I put down the setup and a trick here
                                      http://www.hv20.com/showthread.php?t=13664
                                      it's been working very well for me. A few times, clients saw my DVD (encode with encoder) that they though tthat was HD.
                                      • 16. Re: Best Quality Exporting From HDV to DVD
                                        mickkeay Level 1
                                        Takyc
                                        Thanks and that is a neat trick with the shortcuts / watch folder in procoder.  And OK re your Matrox intermediate. I will match my source for output from AME, feed it into Procoder as see how the MPEG2s do in Encore.    I am surprised there is no Procoder 4 yet. v3 seems to have been around for ages. Will let you know how I get on
                                        • 17. Re: Best Quality Exporting From HDV to DVD
                                          Takyc Level 1
                                          You are welcome.
                                          There're more tricks to that. Encore is very flaky on the file import from Procoder. I didn't bother H.264 because encore is just not going to work well at all (with lots of unknown strange error with only a error code). To encode MPEG-2 for BD authoring, I found out I have to rename all .m2v to .mpg. Then encore is very happy to accept the file. No problem at all.
                                          Matrox RTx2 card is another great investment. actually their Matrox I-Frame HD AVI codec is free to download and use on a machine without the matrox card. Otherwise, you will hae to come up some intermediaate codec or lossless codec.
                                          Taky
                                          • 18. Re: Best Quality Exporting From HDV to DVD
                                            spreeni Level 1
                                            Dan,
                                            thanks for the hint on the MT version. You're right, this speeds up encoding a lot. Now the import avs-script via plugin way isn't faster anymore.
                                            I tested AME in TFF and BFF and you're right again. I cannot see a difference other than the different field types. I wonder why Matrox recommend to use this setting for better quality...
                                            But nevertheless the result of AME using MRQ seems to be slightly sharper but with a bit more contrast than the avisynth file, so it might be some kind of optical illusion. But the performance of the avisynth method is much better. I did my tests with DVCProHD 1080i50 clips to PAL, I don't know if this format affects my results.
                                            Anyway Dan, thanks for your work. We now need some kind of program or script that does the steps (i-frame export - script writing - vdubbing to lagarith) automatically
                                            • 19. Re: Best Quality Exporting From HDV to DVD
                                              Dan Isaacs Level 2
                                              Well, you can (kind of) do it:
                                              1. Batch export multiple sequences MPEG2 I-frame .mpv + .wav files from AME
                                              2. Use the AviSynth Batch Scripter utility to create a multiple .avs files (template like such)
                                              3. Open VirtualDub and set Lagarith codec + Fast compress. Then use VirtualDub's Job Control menu to batch your .avs scripts to .avi files
                                              video = "%PATH%/%CLIP%.m2v"
                                              audio = "%PATH%/%CLIP%.wav"
                                              FFMpegSource(video)
                                              I would need to see the original + both outputs to really tell you anything here. It is possible that the more jagged deinterlacing from AME could pass as extra "sharpness"… but there is just no way it can be "sharper" in any real sense. The type of scaling I use in the script is much sharper than Adobe's.
                                              However, if you find you want more sharpness, take a look the parameters for hd2sd() for sharpening and noise reduction : Sharpness, NR, GrapeSmootherAmount. You may also want to experiment with DeintMethod=1 (the default is 2) … which will use a more accurate deinterlacer (but MUCH slower).
                                              For example, you can modify the last line of the script:
                                              hd2sd(OutputColorSpace="YUY2", OutputBFF=true, DeintMethod=1, Sharpness=0.5, NR=2, GrapeSmootherAmount=20)
                                              One of many possibilties… see the hd2sd.txt file for more information. As I mentioned a few posts back, stay tuned for some updates: Next version will have even better deinterlacing options.
                                              • 20. Re: Best Quality Exporting From HDV to DVD
                                                spreeni Level 1
                                                Dan,
                                                thank you for the link, this could be a timesaver.
                                                yes, I think I'll have to spend some more hours for testing all these options, I'll do.
                                                I made an archive with a short test sequence. http://www.mir-studios.de/test.zip . Files in the archive:
                                                - mpeg2-i-frame.m2v + .wav (source clip)
                                                - premiere.avs (avisynth script)
                                                - premiere_AME_MRQ.m2v (exported from PPro timeline (MRQ enabled), clip in timeline is DVCProHD 1080i50)
                                                - avisynth_AME.m2v (Lagarith-AVI encoded in AME with same settings as above expect MRQ)
                                                You can campare detail sharpness pretty good at frame 100-105. I noticed some kind of color shift when comparing the avs.clip in VDub with the other converted SD clips. Look at the child's red pullover. The color tone of the .avs clip looks different. Is this an effect of the 10-bit dc-precision used by the MPEG2-I-Frame settings or are there used different ITU colorspaces? I guess the result must be right because the clip exported directly from timeline looks same than the intra-avisynth-clip in that point.
                                                Btw, I use the YUV2 mode of Lagarith as it was recommend to me by the author when using clips in YUV2 colorspace, do you think so, too?
                                                • 21. Re: Best Quality Exporting From HDV to DVD
                                                  Dan Isaacs Level 2
                                                  Spreeni – First, thanks for taking the time to run the test and upload the stuff for me. I was able to catch one issue in hd2sd() : I made a patch to it a while back, and in so doing caused the horizontal scaling to round down (in multiples of 4) to 700 instead of up to 704. This was an issue when WidescreenType=2,as in your sample. Not really a huge deal (the "correct" width without rounding would be 702, so it's the same error on either side). However, the "industry standard" width is 704, so it has now been fixed again and uploaded —> hd2sd package (updated)
                                                  Normally, I suggest using the default WidescreenType, which crops a tiny bit from the top and bottom instead. This is actually a little more accurate, PAR-wise … and you don't get those black bars on the sides.
                                                  WidescreenType issues aside, I did a quick comparison of the AME MRQ vs. hd2sd output sampled you provided:
                                                  1. AME MRQ is NOT clipping the extreme highlights from the video. I was actually surprised to see this. Since this is output for DVD, the range should be limited to 16-235 and it is not. It appears to be the original 16-255 range of the camera. Adobe's output is NOT legal color values for DVD.
                                                  2. AME MRQ's output shows more noisy artifacts, which is surprising considering that the AviSynth workflow uses an MPEG intermediary. This is probably a byproduct of the Adobe's deinterlacer.
                                                  3. AME MRQ's output shows strong ringing artifacts (look at flowers on the girl's sweater). This is probably what you perceived as greater contrast and sharpness. It may look "sharper", but it does not look natural.
                                                  4. Other than the black ringing artifacts and unclamped highlights, the color are pretty much exactly the same: The histograms in the video-legal ranges of 16-235 are otherwise practically identical.
                                                  Your clip was apparently a handheld shot. These can be tricky to deinterlace even with very sophisticated deinterlacing. However, in some cases static shots show up problems that are not apparent in fast-moving shots. Static regions require a very "stable" deinterlacer. I have noticed that Adobe's MRQ deinterlacing has a tendency to "shimmer" on sharp, static scenes. It also does not do a very good job of preserving sharp diagonal lines.
                                                  • 22. Re: Best Quality Exporting From HDV to DVD
                                                    spreeni Level 1
                                                    Dan,
                                                    thanks for analyzing my test clips, I didn't recognized these noisy ringing artifacts before but this explains pretty well why picture seems to be slightly sharper in AME. A question to this color range problem: How does your Avisynth-function handle this compared to AME? Is the range 16-255 compressed to 16-235 or does it simply cut the superbright parts? And, although it's not legal, if I want to keep these superbright parts, do I have to set parameters "LimitWhite, LimitBlack, LimitColor" to false?
                                                    In another post I read of your "softlimiter" function. Is it possible to combine this with hd2sd or is this unnecessary?
                                                    Another point: In the doc of hd2sd I found this:
                                                    parameter:      OutputColorSpace
                                                    values:         "RGB32", "RGB24", "YUY2", "YV12"
                                                    default:    YV12
                                                    This sets the output color space. This may need to be set for your encoder:
                                                    use "YUY2" for CCE or ProCoder
                                                    use "YV12" for HCEncoder or QuEnc
                                                    use "RGB24" for TMPEG, Adobe Media Encoder, Encore or output to RGB .avi
                                                    use "RGB32" for output to RGB .avi
                                                    I'm a little bit confused which color space is recommended for AME. RGB24 as stated above or YUV2 as you recommend at top of this post? I know this function was originally written for CS3 so I'm not sure which way would be best for CS4.
                                                    • 23. Re: Best Quality Exporting From HDV to DVD
                                                      Dan Isaacs Level 2
                                                      Well, so long as you limit the range to safe colors in AviSynth (which hd2sd does by default), it should make no difference (as far as I can tell). You might as well use YUY2, since it will make the Lagarith AVI a bit smaller. Using YUY2 wil also provide the option of keeping "unsafe" colors, while RGB will clip them entirely.
                                                      Correct. However: It is unlikely that your camera records useful signal in the 0-16 luminance range, so any pixels in that range are probably anomalous anyway. I'd suggest leaving LimitBlack=true (default)
                                                      And, yes, hd2sd() just clips (limits) the ranges. Scaling the values would affect the overall contrast, which is not what we want here.
                                                      Sure, it will work fine… The only downside is that if you are converting an edited sequence that contains RGB material (such as clips to which you have applied filters like Unsharp Mask, etc.). In this case, already "safe" highlights can get muted a little … but this should not be terribly noticeable anyway. (it would only affect a range of around 210 to 235, and only very slightly)
                                                      To use SoftLimiter, make sure that you are outputting YUY2 colorspace from hd2sd, then place SoftLimiter() at the end of the script:
                                                      hd2sd(LimitWhite=false, LimitColor=false, LimitBlack=false, OutputColorSpace="YUY2")
                                                      SoftLimiter()
                                                      • 24. Re: Best Quality Exporting From HDV to DVD
                                                        Promter
                                                        Hello all,
                                                        This post is great and filled with super great information.
                                                        A lot of it a little bit over my level of pixel breakdown, color sampling, and luma levels understanding but that's ok I don't want to get that deep into it yet.
                                                        On the other hand I came to the board looking for not the best quality settings but the easiest and fastest.
                                                        The particular project that I'm trying to export onto DVD does not need to be in the best possible quality.
                                                        It will be watched at home by my client and his family on their hd set but it's an event where his daughter was singing a few songs and he wanted it on DVD.
                                                        So here's the thing, I shot this on my Panasonic HVX200A at 720p / 24fps on the P2 Card.
                                                        I dragged and dropped the P2 Content in a folder I made on my desktop for this project on my dell laptop.
                                                        I'm done with the edit on CS4. It's a 23minute timeline total.
                                                        The sequence settings for my timeline is 23.976 and match the pixel aspect ratio of my footage of 960x720 / 1.333 the timeline started off yellow to begin with the whole time, hmmm...? I don't know if this is because I should have selected a straight 24fps timeline to match the footage. (but anyway that's another topic)
                                                        As for now here is where I need help.
                                                        I'm new to CS4.
                                                        On CS3 I used to export to encore and done!
                                                        Well... CS4 Does not have that option when I go to "export"
                                                        So I read somewhere that the easiest thing was to export to EDL and in ENCORE import EDL and my Premiere timeline would open in ENCORE.
                                                        I have tried that a few times and can't figure this thing out.
                                                        I have ENCORE CS4 and it's my first time to use it. I did use ENCORE CS3 before.
                                                        Can someone please tell me the easiest way to put my project on a DVD with this new CS4 stuff?
                                                        Also if you guys think I should start this topic on a new thread all together please let me know as well.
                                                        Thank you in advance for your help.
                                                        • 25. Re: Best Quality Exporting From HDV to DVD
                                                          Jeff Bellune Level 5
                                                          "Easiest" is to use Dynamic Link to add your Pr sequence to the En SD DVD project.  Put it in a timeline and build the project.  Done.
                                                          Unfortunately, the finished disc will have issues:
                                                          1. The frame rate will get converted incorrectly by Encore and it will stutter and jump on camera pans and cross-frame motion.
                                                          2. The quality of the scaling from HD to SD will be well below average, and you will lose a lot more of the original HD quality than you should (maybe even to the point of sucking out loud).
                                                          The "best" way to do it in CS4 is:
                                                          1. Nest your finished HD sequence in a progressive 24p SD sequence and scale it down appropriately.  Set the SD sequence to Maximum Render Quality.  That ensures that the AME will encode with MRQ, which triggers Premiere's high-quality scaling algorithm.  The downside to MRQ is the render time.  I get about 4 - 5 fps on an 8-core, 16 GB RAM Vista 64 machine with all 8 cores pegged during rendering.
                                                          2. Export the SD sequence to MPEG2-DVD.  Start with the NTSC Widescreen High Quality 23.976 preset and adjust the video encoding parameters to reflect an appropriate target, min and max bit rate.  For your 23-minute program, setting min to 3.5 Mbps, target to 7 Mbps and max to 8 Mbps should produce very nice results.  If you have quality media, a quality burner with up-to-date firmware and you burn at no more than 1/2 the rated speed of the blank media, you can probably get away with a target bit rate of 8 and a max of 9.  Set the GOP to M=12 and N=3.  You can encode your audio to AC3 either in the AME or in Encore.
                                                          3. After you've had time to watch the entire extended version of the Lord of the Rings trilogy, the finished .m2v and .wav (.ac3) files will be ready to import into En.  Make sure the .m2v (and the .ac3, if you chose that format) imports into En as "Don't Transcode".  Add them to a timeline and build the project.
                                                          Your results won't be as spectacular as using Dan's hd2sd() script, but they'll be pretty darn good nonetheless.
                                                          -Jeff
                                                          • 26. Re: Best Quality Exporting From HDV to DVD
                                                            Promter Level 1
                                                            Wow Jeff,
                                                            that's some pretty awesome stuff!
                                                            but really what is the easiest way? naaa... I'm just kidding!
                                                            I will most definitely use Dan's workflow on 90% of my projects I'm sure but as for this one I'll try it your way.
                                                            Nesting into an SD timeline and rescaling hmmm... didn't think about that.
                                                            Actually what I thought was that exporting my HD timeline the AME would just convert it to SD when selecting MPEG2-DVD on the encoder drop down templates.
                                                            I'm glad I posted the question because I wasn't really sure and I do want to keep at least some decent quality on this
                                                            As to rendering time, the first thing I was able to get my hands on was the Matrix collection and that thing has about 8 DVDs!
                                                            so I think I'm ready
                                                            The second thing I have is a second laptop for these situations. Yes I bought 2 just because of renders.
                                                            So... with that said, I think I'm going to go ahead and give this a swirl and see what comes up.
                                                            Thank you so many millions of times.
                                                            -Promter-
                                                            • 27. Re: Best Quality Exporting From HDV to DVD
                                                              You can do that.  But one of life's great mysteries is why you get different results by doing it that way than by nesting first.  Even if you select Maximum Render Quality from the flyout menu of the AME Video tab, you still get different results.
                                                              Here's the deal.  If you don't nest, but you still select MRQ in the AME, the render takes 2 - 3 times as long as without MRQ, but only 1/2 to 1/3 the time required for rendering the nested sequence using MRQ.  The quality falls somewhere in the middle as well.  I don't know how Adobe pulled that off, but I bet it's not intentional.
                                                              Try testing that method on a short segment of your sequence.  See if the quality is "good enough".
                                                              -Jeff
                                                              • 28. Re: Best Quality Exporting From HDV to DVD
        Promter Level 1
        when I went to bed last night I left it rendering straight HD to AME selecting MPEG2-DVD as a test before I got any replies to the post so I have that file ready to be checked.
        I'll do the nesting now and try it that way and see what the quality difference may be.
        talk to you soon,
        thanks,
        -Promter-
        • 29. Re: Best Quality Exporting From HDV to DVD
        Promter Level 1
        Jeff,
        guess what? my options to set the GOP only goes up to 8 on the "M" and the "N" only goes as low as 8 could that be because I have a 32bit machine?
        who knows....
        but what do you suggest ?  I have attached an image of my screen.
        thanks,
        -Promter-
        • 30. Re: Best Quality Exporting From HDV to DVD
        Promter Level 1
        oh I forgot one more thing.....
        under "Basic Video Settings\ frame rate, do I also change that to 24fps or do I leave it at 29.97?
        thanks
        • 31. Re: Best Quality Exporting From HDV to DVD
        My bad.  I mistyped.  Set N=12 and M=3.
        EDIT: I just saw your most recent post.  Better to start with the NTSC Widescreen 23.976 preset and modify that.
        -Jeff
        • 32. Re: Best Quality Exporting From HDV to DVD
        Promter Level 1
        Jeff,
        With your exact instructions my 23minute timeline renderer total time was a wopping 59m 53s
        Now I'm going to import into ECS4 and see if I can burn this DVD.
        I should be goog to go from here, thanks a million for your help.
        I'm going to burn both DVDs, one from last night letting AME go from HD to SD, and then the one with your settings that just finished.
        I'll be back to comment on the results,
        and once again thank you!
        -Promter-
        • 33. Re: Best Quality Exporting From HDV to DVD
        tclark513 Level 3
        You guys might want to try this method:
        http://cineform.blogspot.com/2008/12/mastering-24p-dvds-from-hd-using.html
        It sounds pretty easy.  I have not had a chance to test it but it sounds like it might be worth a try.
        I know this is using Cineform but maybe exporting 1080p from premiere first might change something.
        Here is a quote from the article:
        The image on the left is soft and badly aliased, and it looks far worse in motion.  Simply exporting the timeline to 1080p first, then using that new file to export to DVD solves the problem, without ever leaving Premiere.
        • 34. Re: Best Quality Exporting From HDV to DVD
        Jeff, one or two passes for the encoding?
        • 35. Re: Best Quality Exporting From HDV to DVD
        Usually, I use 2 passes because I'm testing for worst-case scenarios.  That's why my render times for the AME and MRQ are as long as they are.  Just remember that I use Dan's hd2sd script for all of my real-world stuff.  Another thing to consider even if you can't or won't use Dan's script is that if your timeline approaches 2 hours, then 2 passes are a good idea for use with the lower bit rates that are needed.  That said, 1 pass may produce acceptable quality for shorter programs.
        -Jeff
        • 36. Re: Best Quality Exporting From HDV to DVD
        Promter Level 1
        I burned both.
        The one where I exported my HD finished timeline directly to AME selecting MPEG2-DVD and letting the AME do the conversion to SD and
        I also burned the one where I created and SD timeline, nested my HD sequence, scaled it properly and exported to AME just like Jeff said.
        It appears that they both came out the same. I really didn't see a difference from one to the other.
        I did notice a little noise in both of them. I don't remember seeing that noise when the edit was finished in Premiere.
        I'm going to play with it a little more and maybe even try Dan's way,
        thanks again,
        -Promter-
        • 37. Re: Best Quality Exporting From HDV to DVD
        I like Dan's methode a lot. I make the timeline into a Cineform avi and convert to dvd-mpeg with HC23.
        Now i am giving this nested hd into sd sequence a spin and see how that turns out.
        I will try out Virtual Dub also, because i finally got the Lagarith codec running on Vista 64.
        I tried out your i-frame mpeg with DGIndex and that turned out pretty good.
        I think i will need the Star Wars 6-pack.
        • 38. Re: Best Quality Exporting From HDV to DVD
        If you use Dan's latest version (@ Dan - is it out of beta yet?), then the DGIndex step isn't required any more.  Just list the .m2v file as an argument for the hd2sd function and hd2sd will invoke the proper source for AviSynth, as well as find any matching audio files.  Like this:
        hd2sd("myI-frameMPEG.m2v", interlaced=false)
        Very cool!
        -Jeff
        • 39. Re: Best Quality Exporting From HDV to DVD
        Dan Isaacs Level 2
        Nope. Sorry, folks… I am still working on it. I always find more stuff I should improve… right now, I am working on better PAR handling and the ability to set arbitrary output width, height, and PAR with automatic cropping or borders.
        1 2 3 Previous Next
