I'm trying to use ASP.NET to retrieve data from the sql server, place in inside an xml and sends the xml to flash to display the data.
However, I'm getting
TypeError: Error #1088: The markup in the document following the root element must be well-formed.
at news_fla::mainTimeline/loaded()
at flash.events::EventDispatcher/dispatchEventFunction()
at flash.events::EventDispatcher/dispatchEvent()
at flash.net::URLLoader/onComplete()
This is my code:
ASP.NET
Protected Sub Page_Load(ByVal sender As Object, ByVal e As System.EventArgs) Handles Me.Load
Dim adapter As SqlDataAdapter
Dim ds As New DataSet
Dim sql As String
Dim con As New SqlConnection("data source = GN80000798-0\SQLEXPRESS2008; initial catalog = EL; integrated security = true")
sql = "select * from news"
Try
con.Open()
adapter = New SqlDataAdapter(sql, con)
adapter.Fill(ds, "data")
con.Close()
Response.ContentType = "text/XML"
Response.HeaderEncoding = Encoding.UTF8
ds.WriteXml(Response.OutputStream, XmlWriteMode.WriteSchema)
MsgBox("Done")
Catch ex As Exception
MsgBox(ex.ToString)
End Try
End Sub
Flash
import flash.xml.*;
var newsrequest:URLRequest = new URLRequest("http://localhost:1179/DB/DB.aspx"); //ASP.NET development server
var newsloader:URLLoader = new URLLoader();
var newsxml:XML;
var dvar:URLVariables = new URLVariables();
dvar.dummy = "dummy";
newsrequest.data = dvar;
newsrequest.method = URLRequestMethod.POST;
newsloader.load(newsrequest);
newsloader.addEventListener(Event.COMPLETE, loaded);
titlenews.autoSize = TextFieldAutoSize.LEFT;
bodynews.autoSize = TextFieldAutoSize.LEFT;
function loaded(event:Event){
newsxml = new XML(event.target.data);
newsxml.ignoreWhitespace = true;
trace(newsxml);
HOWEVER, if i replace the
"ds.WriteXml(Response.OutputStream, XmlWriteMode.WriteSchema)"
with
"ds.WriteXml("C:\new.xml")
it works. But i dont wan a .xml file residing in the server. so i hope that the .xml file would be cleared off as soon as the request is done.
Did i do something wrong?
PS: I don't know if i post this in the correct section but since it's related to AS3, thats why i post it here. sorry if i made a mistake.
Please paste the following line as first statement in loaded function, also compare the output of the following line with expected output from ASP page.
trace(event.target.data);
The error is causing due to the fact that XML received is not well formed.
I guess the problem is with write XML you are getting some additional tag elements and these are not wellformed. so flash is giving error.
