1 Reply Latest reply on Jul 5, 2009 11:03 PM by anirudhs
    Read and convert large logfiles.
    zarkam1
      Hi!
      Im trying to do a little air app, that loads log files from our system, divides the logs according to some column name, and then I use the timestamps to
      generate charts, to ease discovering timing problems etc.
      First I used
      fileStream.open(myFile, FileMode.READ);
      arr=fileStream.readUTFBytes(fileStream.bytesAvailable).split("\r");
      which worked nicely.  (20 MB logfiles worked)
      But when I try to load really large logs (85 MB)
      I tried to use
      fileStream.openAsync(myFile, FileMode.READ)
      and then
      private function onFileProgress(p_evt:ProgressEvent):void
          if (_fileStream.bytesAvailable > 8000)
          giantstring+=_fileStream.readUTFBytes(_fileStream.bytesAvailable);
      and then in
      private function onFileComplete .......
      I i tried something similiar as above first:
      arr= giantstring.).split("\r");
      but it didnt work.
      Now Im trying to
      read each line in the giantstring and push it into an array(tried 10 MB) but gets error when trying the big one.
      (string length = 90835506 )
      Anyone have some suggestions ? Can it work, loading the filestream into an array, or should i divide the logfile into lesser ones and load them one after another?
      (Logfile looks like this:
      2009-06-12 15:52:32.007 | u30385_11964.090612.155231940.006 | se.rsv.fh.mt.to.FhMottagningTO.rensaKlaraMeddelanden | 0 | [] | 1335
      2009-06-12 15:52:32.007 | u30385_11964.090612.155231940.005 | se.rsv.at.prt.ph.AtPhProcessHanterareTO.initieraInkorgsOptimering | 0 | [] | 2618
      (I raised the heap of Flex Builder, didnt help)
      Best Regards
      Lukas
