1. Re: Unable to rezise any object or text box
Wade_Zimmerman Jun 16, 2009 8:28 AM (in response to 123qwaszx)They must be locked command control 2.
2. Re: Unable to rezise any object or text box
123qwaszx Jun 16, 2009 9:20 AM (in response to 123qwaszx)thanks but It doesn't work
3. Re: Unable to rezise any object or text box
Ozzwoman9 Jun 16, 2009 9:22 AM (in response to 123qwaszx)Is it on a locked Layer?
Can you select it at all?
4. Re: Unable to rezise any object or text box
Larry G. Schneider Jun 16, 2009 9:28 AM (in response to Ozzwoman9)Try Unlock All from the Object menu. Cmd-Opt-2
5. Re: Unable to rezise any object or text box
Harron K. Appleman Jun 16, 2009 9:28 AM (in response to 123qwaszx)What resizing methods have you tried?
6. Re: Unable to rezise any object or text box
Wade_Zimmerman Jun 16, 2009 9:35 AM (in response to 123qwaszx)Ooops I mean command option 2 as larry stated.
You have the objects locked.
7. Re: Unable to rezise any object or text box
123qwaszx Jun 16, 2009 3:45 PM (in response to 123qwaszx)Nothing is locked and i'm still unable to resize my objects with the selection tool. I can only use transform/scale, pls help me, I want the short way back!!
8. Re: Unable to rezise any object or text box
123qwaszx Jun 16, 2009 3:49 PM (in response to 123qwaszx)And yes I can select it, I can move it, I can transform it threw the transform pannel but I can't resize it with the selection tool as usual and it's really frustrating.
9. Re: Unable to rezise any object or text box
Jesseham Jun 16, 2009 4:24 PM (in response to 123qwaszx)Can you attach a screenshot of a selected object? Are you sure that you're using the move tool? (the black arrow accessed by hitting "v") Is this happening to one object only or everything that you create? In a new document?
You'll have to bear with the rudimentary questions for such a fundamental issue.
10. Re: Unable to rezise any object or text box
Steve Fairbairn Jun 16, 2009 4:30 PM (in response to 123qwaszx)Did you perchance turn bounding boxes off?
Otherwise I always prefer S for scale and R for rotate, that way you can mark the centre of scaling/ rotating accurately.
11. Re: Unable to rezise any object or text box
123qwaszx Jun 16, 2009 4:37 PM (in response to Steve Fairbairn)As I've said, bounding box are already turned on.
It happens with any object or any text box in any document, even if I create a new document. I can't resize or rotate with the move tool (black arrow) and I also can't transform objects (moving only one line or one point..) with the direct selection tool (white arrow). The only thing I can do white these tools is select.
12. Re: Unable to rezise any object or text box
[scott] Jun 16, 2009 4:44 PM (in response to 123qwaszx)Trash your preferences.
Hold Command-Option-Shift down while launching Illustrator.
13. Re: Unable to rezise any object or text box
123qwaszx Jun 16, 2009 4:47 PM (in response to [scott])Do you know the shorcut for a pc because i'm not on a mac?
14. Re: Unable to rezise any object or text box
[scott] Jun 16, 2009 5:02 PM (in response to 123qwaszx)I wish I did. I can only guess though... Ctrl-Alt-Shift + launch AI. But I know Ctrl-Alt-Shift has other repercussions on a PC at times.
Essentially You want to remove the "Settings" files. I think on a PC they are located directly in the Adobe Illustrator Folder. Try moving the Settings folder to your desktop and then relaunching Illustrator.
15. Re: Unable to rezise any object or text box
Harron K. Appleman Jun 16, 2009 6:01 PM (in response to 123qwaszx)2. From Help: About Preferences
3. Shift + Ctrl + Alt during program launch is the keyboard shortcut method for Win.
16. Re: Unable to rezise any object or text box
caitiegirl Aug 14, 2009 8:51 PM (in response to 123qwaszx)I had this same exact problem tonight. Been in Illustrator for several hours and then bah! couldnt do anything.
Thank you for posting the question and thank you to those that provided the answer to fixing!!! saved me a few hours frustration!
17. Re: Unable to rezise any object or text box
Wade_Zimmerman Aug 15, 2009 9:45 AM (in response to caitiegirl)123 should mark this answered as we can see it would help others.
18. Re: Unable to rezise any object or text box
3frx Oct 7, 2009 1:15 PM (in response to 123qwaszx)did you try Shift+ctrl+B?
19. Re: Unable to rezise any object or text box
Harron K. Appleman Oct 7, 2009 1:30 PM (in response to 3frx)did you try Shift+ctrl+B?
Please reread original post as well as posts 10 and 11.
20. Re: Unable to rezise any object or text box
linnrah Nov 4, 2009 11:33 AM (in response to 123qwaszx)THANK YOU!!!
Thought I in some way had broken the whole program....
beginning to panic...
and then i found this. happy again:D
21. Re: Unable to rezise any object or text box
jarmachacek Feb 18, 2010 2:01 AM (in response to 123qwaszx)I have the same problem in Illustrator CS3 and InDesign CS3 too. Verifying permissions, deleting preferences, reboot, reinstalling CS3, using CS3 clean scripts, reinstalling the system - nothing helped. I'm desperate, please, help me... Thank you in advance for any ideas!
Mac OS X 10.6.2, Adobe CS3
22. Re: Unable to rezise any object or text box
Wade_Zimmerman Feb 18, 2010 6:30 AM (in response to jarmachacek)Try creating a new user account and log into that and see if all is not now right.
23. Re: Unable to rezise any object or text box
jarmachacek Feb 19, 2010 1:05 PM (in response to Wade_Zimmerman)I'm stupid that I have thought!!! MEGA-THNX!!! All is OK!
24. Re: Unable to rezise any object or text box
jarmachacek Feb 20, 2010 6:53 AM (in response to Wade_Zimmerman)joy was premature, even under the new account does not work I do not know what to do...
25. Re: Unable to rezise any object or text box
jarmachacek Feb 21, 2010 4:22 AM (in response to 123qwaszx)Final solution is to disable BTT (BetterTouchTool - tool for Apple Magic Mouse)!!!!
26. Re: Unable to rezise any object or text box
Wade_Zimmerman Feb 21, 2010 10:03 AM (in response to jarmachacek)jarmachacek
FYI when ever you come across a problem that all of a sudden pops up out of the blue for no reason, you no there is a reason and it is always an update a new install of a font, application, a haxie or a plug in and or a profile other form of calibration.
The only other things to suspect new or failing hardware. In the case of new hardware usually the drivers and usually going on line for the update solves the problem as you are probably not the first one to notice it.
However you may have been the first one to pin it down in which case you will do everyone a big favor by reporting it to Apple and who knows maybe the will ask you to become a Apple Seed. That's one of their beta software and hardware testers.
In the case of hardware failure it can effect your system as if you have a bug in the application and surprisingly from my experience…and this is hard to believe…it usually effects one application first and as the failure becomes more complete it starts to affect other applications and then finally the system.
A software update just disconnected one of my printers from a wireless network and I could not connect in frustration I turned it off for the third time and said to myself that I was just going to forget about this turned it back on and it connected.
So restarting often solves problems as well.
Check for updates to for an update from Apple or report if they fix it everybody will be pleased.
27. Re: Unable to rezise any object or text box
drhite77 Jun 22, 2010 1:46 AM (in response to 123qwaszx)I had same exact problem. RESETing bounding box did the trick. Object>Transform>Reset Bounding Box
28. Re: Unable to rezise any object or text box
NewLifePuppet Feb 7, 2012 11:52 AM (in response to 123qwaszx)Shift + Ctrl + B will fix the resizing problem. You probably hit a hot key combination by mistake. I'm not sure the combination on Mac, but it's under View > Hide/Show Bounding Box
Ctrl + H will enable the nodes again. Again, probably a keyboard accident. It's also under View > Hide/Show Edges.
Hope this helps. God bless you all!
29. Re: Unable to rezise any object or text box
dragonspyder Aug 27, 2014 2:21 PM (in response to caitiegirl)THIS DIDNT WORK FOR ME
30. Re: Unable to rezise any object or text box
Larry G. Schneider Aug 27, 2014 2:48 PM (in response to dragonspyder)What didn't work? If you are trying to reset the preferences then you need to mash the keys as you click on Open/restart of the application. If you do it right you will get a confirmation dialog asking if you wish to reset the preferences.
31. Re: Unable to rezise any object or text box
VuVu Sep 2, 2014 10:53 AM (in response to 123qwaszx)HI 123qwaszx, I went to VIEW and selected SHOW BOUNDING BOX. If you select HID BOUNDING BOX you will see the situation you describe reappear.
32. Re: Unable to rezise any object or text box
VuVu Sep 2, 2014 10:54 AM (in response to VuVu)*HIDE
33. Re: Unable to rezise any object or text box
tinagee Sep 16, 2014 11:06 AM (in response to NewLifePuppet)I just encounter this problem. Shift + Ctrl + B solution worked for me. Thanks
34. Re: Unable to rezise any object or text box
pedroangelo Oct 2, 2014 12:39 PM (in response to 123qwaszx)The same problem happened to me. The solution i found in another forum:
"Under the "View" menu, make sure it says "hide bounding box" - that means it's currently on. If it's currently off, as is probably the case, it will say "show bounding box". Click on it. Hopefully that will solve your problem.
The keyboard shortcut for that is ctrl-shift-B. "
35. Re: Unable to rezise any object or text box
chrisenter Oct 16, 2014 8:38 AM (in response to 123qwaszx)This is also happening when I draw a text box. I am having the same issue and tried all of the recommendations. Nothing has worked. If anybody has other suggestions, I would appreciate it.
36. Re: Unable to rezise any object or text box
luvbug900 Oct 16, 2014 2:20 PM (in response to 123qwaszx)Try hitting E! None of the others worked for me but this did the trick!
37. Re: Unable to rezise any object or text box
chrisenter Oct 17, 2014 6:13 AM (in response to luvbug900)Worked! Thank you. Why would you change that in the program? Errr.
38. Re: Unable to rezise any object or text box
ichigokazuki Oct 29, 2014 4:15 PM (in response to NewLifePuppet)You saved me. I couldn't fix it all all, until you mentioned going under view for showing the edges and I saw that somehow I clicked do not show bounding box, clicked it again and now I finally complete my project.
Thank you!
39. Re: Unable to rezise any object or text box
bettywacka Dec 2, 2014 4:51 AM (in response to drhite77)Resetting the bounding box just worked for me on the mac. Thank you so much!! And breathe... life is good again!
