6 Replies Latest reply on Jun 28, 2009 10:35 AM by the_wine_snob
    Entry Point Not Found
    Ph1loSophy
      I tried to open the Adobe media encoder and get the message :the procedure entry point ??0NewhandlerInitializer@ErrorManager@config@dvacore@@QAE@XZ could not be located in the dynamic link library dvacore.dll. I can load Premier Pro okay.
        • 1. Re: Entry Point Not Found
          the_wine_snob Level 9
          A Repair Installation can often fix missing, or corrupt .dll's. This would be my first course of action.
          • 2. Re: Entry Point Not Found
            Ph1loSophy Level 1
            I have no repair option.  I could uninstall a goodly chunk of the CS4 Master Suite to get encoder to run standalone; but I'm not sure it's worth it to me.  thanks anyway
            • 3. Re: Entry Point Not Found
              Unless Adobe has made a major change, it works this way:
              1.) Insert Installation disc and initialize the Installer. Be patient.
              2.) You should get a dialog screen with the components in the suite that you wish to install. Choose PrPro.
              3.) The installer module will have done a survey of your system, and will now do another one. Be patient.
              4.) Once this survey is complete, you should get another dialog screen with two options: Uninstall, or Repair Install.
              5.) Choose Repair Install.
              Hope that this not only works, but also fixes your issue.
              [Edit] At several points you may also be asked to replace the disc in the drive with another disc from the set. You do have the discs, and are not installing from a download, right?
              • 4. Re: Entry Point Not Found
                Ph1loSophy Level 1
                I ended up doing a clean install of Windows 7 beta.  The reload of Master Suite CS4 went without a hitch.  Everything works great.  For what it's worth, the Master Suite doesn't give you the options the single program disks apparently do - based on your advice.
                My method: 1) use easy transfer to copy my user files from the laptop to an external USB drive
                2) do clean install (but not with a disk format-repartitioning)
                3) do install of master suite
                4) use easy transfer to copy from usb to different user on laptop
                5) copy my projects from olduser files to new
                • 5. Re: Entry Point Not Found
                  Ph1loSophy Level 1
                  I LOVE Adobe forums.  Thanks.
                  • 6. Re: Entry Point Not Found
                    Glad that you got it sorted, and thanks for reporting back.
                    Sorry that it came to a full reinstallation, but sometimes that is just the best way to handle things like this. I'm a lazy sot, so I always look for a good way, without all of the work.
