0 Replies Latest reply on Sep 3, 2008 8:28 AM by ScottServen
    Security Error when trying to access web service
      I have an app that connects over HTTPS to a web service on our internal network. The interface to the web service was created by using the WSDL Import function of the Flex IDE.
      I can run the app and retrieve data without a problem when I run from the debug-bin folder that the Flex IDE compiles to. However, I cannot connect to the web service from anywhere else, such as a different location on my own local drives, a network drive, or another persons machine.
      I've setup a local instance of Apache with mod_ssl so I could host the app under an HTTPS connection itself, which the documentation seemed to imply that would work. However, when I run the app, I get:
      [FaultEvent fault=[RPC Fault faultString="Security error accessing url" faultCode="Channel.Security.Error" faultDetail="Destination: DefaultHTTPS"] messageId=null type="fault" bubbles=true cancelable=true eventPhase=2]
      I am accessing the app by going to https://mymachine.companydomain.com/myapp.html, and the web service is being accessed through https://webservice.companydomain.com/.
      Anybody have any thoughts on what I should be looking at? I've been searching and trying things for a few days with no luck. Any help would be appreciated. Thanks.
